Ok, I'll admit when I'm wrong - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 07-25-2018, 12:01 PM   #11 (permalink)
jttheclockman's Avatar
Photos: 83
Default
methods, no right and wrong just different.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 07-25-2018, 12:08 PM   #12 (permalink)
Photos: 21
Default
Quote:
In this case I was just flat wrong lol Then again, there are better products on the market now that certainly make it less risky to do in a hurry I suppose.
McKenzie Penworks is offline   Reply With Quote Top
Old 07-25-2018, 12:21 PM   #13 (permalink)
edstreet's Avatar
Photos: 2
Default
As I have stated numerous times facts are facts and not subjected to opinions. If a fact shows method A uses more CA than method B then method A is better than method B if you are discussing amount of CA needed.
__________________
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Advertisement
Old 07-25-2018, 02:37 PM   #14 (permalink)
Photos: 0
Default
I switched from paper towels to little component bags, and apply at about 350 rpm with no splash. I didn't do well with accelerators either, but when I switched to Mercury Flex Mike (mecompco) suggested that it is formulated to work best with their accelerator between coats. Sure enough--it's a beautiful thing!!
Tim--wood is nice and usually my preferred medium, and turn all you want...just don't stop making your blanks!!
earl
greenacres2 is offline   Reply With Quote Top
Old 07-25-2018, 03:09 PM   #15 (permalink)
Photos: 21
Default
The component bag is really brilliant from a business standpoint too. You've already bought the bag with the kit so save yourself a few pennies. I'll have to give it a shot and see if it works as well as the nitrile finger cots. No worries Early, DiamondCast will be around a while. I've got that minisplit heat pump in the shop to pay for after all!
Old 07-25-2018, 03:19 PM   #16 (permalink)
edstreet's Avatar
Photos: 2
Default
A good and proper accelerator, not acetone based, is imperative for a great finish. Heptane, Naphtha etc makes great accelerators that will not damage the CA. Remember acetone dissolves CA and eats plastic and metal alike. Yet itís used as an accelerator. Also acetone is very harsh in the polymerization cycle.
__________________
Old 12-17-2018, 03:21 PM   #17 (permalink)
Photos: 0
Default
Quote:
I know this is an older thread but just ran across the idea of using naphtha as an accelerator. Would I use the big box product and apply with a little spray bottle?
ramaroodle is offline   Reply With Quote Top
Old 12-17-2018, 04:35 PM   #18 (permalink)
Sylvanite's Avatar
Photos: 35
Default
Quote:
CA glue is acidic and polymerizes with the addition of a mild base (pretty much anything with an -OH ion).
If you look at the MSDS for factory accelerator, you'll see that in addition to the naphtha, heptane, hexane, butane, or acetone, they contain (typically around 1%) an amine such as n, n-dimethyl-p-toluidine. That's the ingredient that promotes the polymerization. The other 99% is just a carrier.
You can try using straight naphtha, but don't be surprised if it doesn't work well.
I hope that helps,
Eric
Sylvanite is online now   Reply With Quote Top
Old 12-17-2018, 04:42 PM   #19 (permalink)
Photos: 0
Default
I hope that helps,
Eric
So, something branded as "accelerator" is a better choice?
Old 12-17-2018, 07:37 PM   #20 (permalink)
magpens's Avatar
Photos: 75
Default
Andy,
I am interested in the possibility of using an alternative to the factory accelerators, if only because the alternative is potentially a lot cheaper.
For that reason, I am following this thread. . I hope you will post any conclusions you come to as the result of your experimentation.
One thing I am wary of is what I have experienced myself, namely that the accelerator recommended for one brand of CA does not always work satisfactorily for a different brand of CA. . Among other concerns, I am puzzled by why that should be the case.
Another thing I am wary of, and concerned about, is playing around with all those nasty chemicals. . I am not a chemist but I am quite sure that acetone, naphtha, and the other things mentioned are potentially quite harmful.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
