Oil finish - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 09-13-2016, 11:55 AM   #1 (permalink)
Photos: 0
Default Oil finish
I am turning my first doe grunt call and the documentation on the kit says to use an oil finish of my choosing on it. Just thought I would get some opinions on what might be the best oil finish for this type of project.
joe966 is offline   Reply With Quote Top
Old 09-13-2016, 12:15 PM   #2 (permalink)
KenV's Avatar
Photos: 0
Default
I like the walnut oil sold for finishing bowls, or the Tru-Oil gunstock finish.
I avoid boiled linseed oil as it continues to darken over time becoming almost black.
(The walnut oil sold in food stores is not the good studd for finishes)
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 09-13-2016, 02:18 PM   #3 (permalink)
Photos: 4
Default
An oil finish can mean just about any film forming finish (poly, varnish, etc) oil varnish blends, wiping varnish or straight penetrating finish (Tung or walnut). Would think poly or varnish might provide the best protection.
__________________
Bill
Wildman is offline   Reply With Quote Top
Advertisement
Old 09-13-2016, 04:38 PM   #4 (permalink)
Photos: 0
Default
I have been using teak oil on my game calls for year, decades. I buy Watco, it easy to find at the big box stores. First coat, I dilute with mineral spirits about 50/50 to get a good penetration of the finish. Subsequent coats at 48 hour intervals. This is the best guide on the Internet. https://www.firearmsforum.com/firearms/article/3037
dogcatcher is offline   Reply With Quote Top
Old 09-13-2016, 06:00 PM   #5 (permalink)
edstreet's Avatar
Photos: 2
Default
Tru-oil contains linseed oil.
__________________
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Old 09-13-2016, 06:13 PM   #6 (permalink)
KenV's Avatar
Photos: 0
Default
Quote:
Indeed it is made from linseed oil, but uses a different process of partial polymerization. It was known as stand oil in years of yore. Because it is partially polymerized by heat in the absence of oxygen, it completes the process of curing differently than the reaction with chemical dryers in BLO.
Tru-Oil is on a lot of firearms, and is an accepted finish for many shooters who are likely to purchase a call.
__________________
Ken Vaughan
Old 09-13-2016, 06:20 PM   #7 (permalink)
EBorraga's Avatar
Photos: 80
Default
I've been using true oil. I really like how it finishes. And so far it's been waterproof.
__________________
Wicked Chickens lay deviled Egg's
Check out my Facebook page at https://www.facebook.com/EBWoodworx/
EBorraga is online now   Reply With Quote Top
Old 09-13-2016, 11:04 PM   #8 (permalink)
Photos: 0
Default
Tru-Oil is overpriced, and not that good for a game call. I have been making predator and duck calls since 1964. From experience hunters take better care of their weapons than they do their game calls. If they treated their weapons like they do game calls, some would have to replace their weapon every few years.
I have tried every finish known to man, and some concoctions that I created myself. The easiest and the best I have found are the oil based varnishes. Next would be spar varnish using a dipping method, but it can be a pain to get consistently until you have some experience at it.
A fair warning, after awhile your teak oil will go bad on you, throw it away, you can try to save it, but it is not worth the expense. Oxygen "spoils" the mix, you can play with the various methods to keep the oxygen out of the can, but like I said, in my case my time and the expense was not worth it. I bought the pint cans of Watco teak oil, usually threw bout half away. Back when I was retailing I would make 48 to 72 at a time and finish the calls with 3 to 4 coats. Dip, then hand wipe the next coats.
Old 10-02-2016, 10:48 AM   #9 (permalink)
Photos: 0
Default Linseed oil VS Tung oil
Tung oil has better water resistance than does linseed oil, according to The Finishing Store.com. For this reason, tung oil is often used on outdoor furniture. Both linseed oil and tung oil dry to thin, satin finishes.
Boiled linseed oil contains drying agents, whereas tung oil does not, so linseed oil dries faster. Tung oil requires sanding between each coat, whereas linseed oil only requires sanding after the first coat. Boiled linseed oil can go rancid, whereas tung oil cannot, according to Canadian Woodworking & Home Improvement. An advantage of boiled linseed oil is that is cheaper than tung oil. Tung oil does not yellow over time.
farmer is offline   Reply With Quote Top
Old 10-04-2016, 07:16 PM   #10 (permalink)
corgicoupe's Avatar
Photos: 0
Default
I believe spar varnish is oil based.
corgicoupe is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
finish , game calls
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
