lkorn
After trying to read and understand most of what has been posted here, I've got a few questions.
1. Do all woods need a "sanding sealer" before sanding/finishing?
2. I've been using "Hut PPP" Brown, then white, the Crystal Coat, then "Shellawax" fiction finishes in the order staed above. Is this the correct order, or should I use the crystal coat, THEN the two polishes? Do the bar polishes leave anything in or on the wood?
3. Is the Crystal coat a shellac formula that can also be used as a sanding sealer?
4. How about Mylands paste wax after all this?
5. I use MM just before polishing, should I be using MM between polishing steps?
Inquiring minds want to know!
