Non c/a finish
TomS
Pataskala, Ohio
What is the most durable finish to put on a wood blank to get a more natural appearance. Sometimes c/a is just too shiny.
hewunch
Albany, GA
You can make CA not shiny. Laquer is good as is plexiglas and wipe on poly. all can be shiny or satin. One way to make it not as shiny is to not go all the way through the MM levels
leehljp
Member Liaison
Tunica, Mississippi,
I would question whether using CA without polishing to a gloss would result in patchy areas of gloss as the user continues to handle (rub) the pen.
Larry
Larry,
I agree also that the pen should be polished to 12000 MM, - for your specific point.
In the original post of those two pens in the link, I mentioned that I went up to 12000 on both pens, and then for the non-shine - I backed down to the 3200 or 3600 until I got the dull finish that I wanted.
And you are right about the gloss from hand rub. I still have the pen and use it off and on. After a year, it has some hand rub shine near the nib, - not a lot but just enough to notice. It does protect well and looks very natural.
grub32
Ohio, USA.
I agree with Hank....CA is the best choice...View Russ Fairfields videos in the library and he mentions how to keep his pens from getting that non-glassy look. Hank's idea is similar to Russ's from the videos.
Grub32
TomS
Pataskala, Ohio
Thanks for all the response. I'm pretty new to this, and I've only done 4 c/a finishes so far. The results have been pretty good, but I'm not sure I would like the super shiny finish on all of the different woods. So far I have mm'd to 12000 on all of them. I'll experiment and try stopping early, or maybe go back to a lower grit after 12000.
marcruby
Warren, Michigan, USA.
I have to admit I got a chuckle when you explained what you did, but I intend to try that. I tried your bushingless idea and it can really save the day. But first I'm going to try using Waterlox -- the idea fascinates me.
Marc
Larry,
hewunch
Albany, GA
WOW, it is so nice to be right for a change. If I gave yall my phone number would you call and tell my wife?:biggrin::biggrin:
leehljp
Member Liaison
Marc
While there are several finishes available here that I have not tried, there are several finishes readily available in the US (and in Euro/Australia) that are hard to find here. Semi-gloss poly's, Waterlox, Deft and Enduro are some that I wish I could get here.
Rudy Vey
South Plainfield, NJ, USA.
Unaxol or Enduro gives a more natural finish than CA. I use Unaxol on pens with wood, like Irish Bog Oak, that has a certain structure and feel to it, that I like to keep and do not want to encase this in a plastic-like finish.
Rangertrek
Bossier City, Louisiana, USA
TM
I have almost completely converted to Turners Magic.
The finish is very consistent and provides a nice sheen wihtout looking like plastic. They also have a lower gloss formula that has a natural look. I have been experimenting with the product on several types of wood. I apply 3 coats of sealer and at least 3-4 of gloss.
The finish looks good, nice depth. The hardness of the finish seems to be good for me. It will scratch, just like CA. I have intentionally rubbed a spot (fingers) on a pen I use daily and have not noticed any loss of sheen. A few of my clients like this finish more than CA. On the other hand, some like the high gloss of CA.
Hope this helps.:wink:
