Mylands cellulose sanding sealer, eee ultrashine wax or both
Swerve87
New Holland,PA.
Would there be any issues with using EEE Ultrashine wax as my final sanding step and then using Mylands cellulose sanding sealer as a good finishing base for CA? Is that redundant or will the EEE give it issues. Any help or advice would be greatly appreciated because I'm new to wood turning and I'm still trying to figure out finishing techniques
mecompco
Fairfield, Maine
I don't think the CA would stick very well to wax of any sort, nor is it necessary. I don't think the sealer is needed, either. The CA will fill any grain and, after sanding/polishing, will leave a mirror finish. Generally, sand to 400 or 600, clean all the dust off (I use acetone, which also removes any oil for oily wood) and apply your CA finish.
Sanding sealer is good if you're doing a friction polish finish, after which a buffing with wax is fine.
Regards,
Michael
Swerve87
New Holland,PA.
What about exotic woods that have a lot of oils in them would a sanding sealer not help in sealing them in and provide a good base for CA or am I misunderstanding the proper use for sanding sealer?
mecompco
Fairfield, Maine
Sanding sealer's purpose is to fill open grain and create a smooth surface in preparation for the finish. To remove sanding dust, oils, and such, you can use DNA, or as I prefer, acetone. After that, so ahead and apply your CA finish.
Wildman
Jacksonville, NC, USA.
If were using lacquer as a final finish your sanding sealer will help you get a build of finish faster. Like,"mecompco," said wiping down your oily wood with DNA or acetone should remove enough oil to allow you to get a coat of CA on there just fine. While technically CA not a wood finish it does form a film with each new coat so acts lot like any other film form finishing material.
farmer
NV
My thoughts are different .
Sanding sealer seals the wood temporary .....if the wood is handled .
The oils in your hands will break down all shellac based sanding sealers .
Sanding sealer is DNA and shellac ....... its watered down shellac ......
You never want to wipe down your wood with denatured alcohol because it remove the oil from the wood ......
The oil in the wood is what makes the woods natural color ..
I haven't found one exotic wood CA wouldn't stick too because it was to oily .
raar25
Glastonbury CT
I have a different approach than some. I always use EEE and clean with DNA. Than I use a lacquer sanding sealer as my final finish. it builds nicely and gives me a gloss finish when buffed out. Because it soaks into the pores it seals and protects but quickly builds up a film as well, best of both worlds. I have used lacquer over CA which I used as a sealer and had no problems with the two sticking so doing it the other way around should not be an issue.
