My Glu Boost Experience - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 10-02-2018, 10:03 PM   #1 (permalink)
TonyL's Avatar
Photos: 6
Default My Glu Boost Experience
This held special interest for given my guitar playing. I sanded to 2000 dry, blew-out the dust, and wiped it down with DNA and let dry.
I applied 3 coats of Blue and 2 coats of Orange. I used GB accelerator between each coat and let it "cure" for at least 2 minutes between coats, a little long between the Orange (really thin stuff). I then sanded from 1500 to 2000 and even used some 0000 steel wool. Oh yeah, I used ordinary, white, bathroom dispenser cheapo, paper towels (same that I use for applying CA finish). I then took the blank to the buffing wheel.
Despite the grain appearing very tight with no open grain or pits, my post-sanding, pre-buffing finish did have some some pits (no visible radial scratches though). Anyway, I brought it over to the buffer and started with white diamond as opposed to the brown Tripoli (trying to go as least aggressive as possible.
I wound-up having to go back to the Tripoli (brown) to remove the pits. Then I buffed through a small section - but it did take a lot more effort to buff-through even though I used less coats. Anyway, re-did the whole thing. Letting it sit over night (12 hours) this time which I don't know how much difference that will make. And there is always user-error (ME) to account for.
I do not regret buying it, and I will definitely use it. I don't think "traditional" CA should "pack its bags yet. I will say that I did use much less (a total of 5 coats).
The instructions call for a minimum of 15 minutes to one full day before working with it. I don't know if the applies to the thin coats that we use. I also want to test my mercury flex CA with the GB accelerator. Time will tell for me; it was faster though because less coats were used (The GB doesn't appear any thick than medium and thin CA, Blue and Orange respectively. I will see what happens with different wood. I am letting it sit over night as I stated above. Luthiers use some pretty soft wood (spruce and cedar) especially for guitar tops. The wood I used was much harder than that (don't know the name). I will take a picture of it when finished. I don't think I will be able to tell the difference in finish between mercury or glu boost. I would continue to use GB, just for the speed. Despite, my initial results, I think it will be very popular.
For what it is worth :-)
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
