Wright
How many of you cross sand MM after using each grit. I do. Is this an unnecessary step? My process: After cross sanding I turn lathe off, dry and clean blank, do the same on all grits.
I almost always forget to do this. But it does improve the look.And yet another option for wood
"Burnishing" after initial sanding
I sand to 400 cross sanding between grits and then burnish the wood. This increases the chatoyance of the wood by closing the grain off and flattening the fibers.
