Micro Mesh Color Chart - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 12-09-2016, 04:41 PM   #1 (permalink)
Herb G's Avatar
Photos: 18
Default Micro Mesh Color Chart
This is a color chart for the Micro Mesh sanding pads.
I looked on here & couldn't find one, so I'm posting this.
In case you lost the chart that came with your pads, you can print out this one instead.
I hope it helps someone.
__________________
Your secrets are safe with me.
There's a good chance I wasn't listening anyway.
My lathes:
Floor Lathe
Bench top lathe
Herb G is offline   Reply With Quote Top
Old 12-09-2016, 05:06 PM   #2 (permalink)
magpens's Avatar
Photos: 63
Default
Thanks, Herb !!!
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 12-09-2016, 05:08 PM   #3 (permalink)
Photos: 7
Default
Heh ... that's a nice lil chart.
Doesn't help me one bit, as mine are all shades of grey. I buy my micromesh at Hobby Lobby. Once I get them out of the package, though ... I write the grit on the white sides of the pads, since each pad is double sided with the same grit on both sides... 6 grits in the package. 3200, 3600, 4000, 6000, 8000, 12000.
__________________
Click Here to go to Pen Turner's Anonymous Meeting
Attendance is not mandatory, unless you're addicted to turning pens.
Skie_M is offline   Reply With Quote Top
Advertisement
Old 01-15-2017, 03:46 AM   #4 (permalink)
Photos: 0
Default
I have a set of these pads.
It needs to be noted by anyone think about buying a set. That some of the shades don't match up very well with "reality". I'm not colour blind & still found it challenging to differentiate between the Black & Grey pads. I think that Teal was also hard to decipher.
rotopenz is offline   Reply With Quote Top
Old 01-15-2017, 04:57 AM   #5 (permalink)
Photos: 0
Default
A trick I use - I learned it here on IAP - is to hold the pads together with one side on the table. With a Magic Marker draw a stripe down one side. Lay the lowest grit down and draw another stripe next to the previous stripe. Continue doing this until you have all of the pads marked. The lowest grit with one stripe, the next grit with two stripes and so on. So then all of your pads are marked with stripes and you know in which order to use them without remembering the colors.
If you use the two sided pads as I do, then take all of the pads and mark an "A" in one corner and then turn the pads over and mark a "B" on the other side. Then as I am using the pads I can readily see which side I have used. And if you drop the pads it is very easy to put the pads back in sequence.
larryc is online now   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
