Math2010
Hi,
I made like 20 pens without problems, but now, the finish is full of little scratches.
I use EZ Bond CA with accelerator (4 thin coats and 4 medium coats). After, dry MM (I read on that forum that it's a personnal choice to use dry vs wet sanding) and I finish with one Plastx coat. The 20 first pens were fantastic. But now... We have to look under a lamp, but that's a lot of scratches. Maybe my MM needs to be washed? Or changed? They are more white then the original colour... But I read that people are making like 100 pens before changing them.
Thank you
Thank you
