Finishing It ain't a pen till it's FINISHED! |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
I had some indications that I might be getting sensitized to CA (burning sinuses) and yep, I have been using a respirator and gloves. I was pretty bummed out since CA gave me a hard and fast-curing finish.
Based on a couple of posts here on IAP, I tried dipping the blanks in Enduro. I dipped them twice, reversing the blank on the second dip. I waited until the blank was just slightly tacky (based on the finish on the bushing) between dips. I did not sand between dips. Wow, that was easy. I set the blanks overnight on the portable oil-filled radiator in my den and was able to micromesh the few dust specks and polish the blanks with Hut's plastic polish (at low speed on my Shopsmith) the next evening. Here is one of the pens I recently did for a church craft show fundraiser. ![]() This system is practically without fumes of any sort and much easier to use - no respirator required.
__________________
******************* Tom in Delaware ![]() |
#3 (permalink) |
Photos:
I have been told that CA dust can cause a allergic reaction in sensitive individuals, another reason I started to get concerned. The dipped Enduro blanks are almost glass smooth, there is almost no sanding involved, but even so I have not read that cured poly is allergenic.
__________________
Advertisement |
#4 (permalink) |
Former Moderator
That looks great. If you wouldn't mind sharing, I'm a little confused by some of your dip comments. Questions:
You said dip twice, based on tacky finish on the bushings - You dip including the bushings? On a mandrel or not? What about finish inside the tube then? Whats your pre-dip stop point? Sand to ?? Micromesh?? Thanks for any info you share!
__________________
![]() Fill in your info!! so we can find out if your near other turners! |
#5 (permalink) | |
Photos:
![]() Quote:
To sand down the few dust nits on the dry blanks, I used nail buffing pads, the pink and white ones that some drugstores and Sally's Beauty Supply sell. The pink side is coarser, but still roughly equal to about 2000/2500 grit paper. The white side is maybe a little coarser than the gray micromesh. I sanded just the nits with the pink side, polished a bit on the white side, followed by gray micromesh and then Huts plastic polish. Took about 5 minutes per blank. Some of the blanks were dust free, those I just gave a quick pass with the white/gray micromesh and plastic polish. I went out yesterday and bought some threaded stove bolts of different lengths and some nylon nuts. I am constructing a rack I can place on the bench and radiator where I can hang the blanks since it is risking fate to have them just sitting on the lower nuts while drying. No kids or pets in the house but still... Hope this helps.
__________________
#8 (permalink) |
Looks like General Finishes makes Enduro:
http://www.generalfinishes.com/ Here's a link to Enduro on Rockler's site: http://www.rockler.com/search_result...12&submit.y=10 I'm definitely going to give this a try!
__________________
Gary Hughes Atherton Pens I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. -Thomas Jefferson |
#9 (permalink) |
Photos:
My brother recently bought (off of E-Bay) a small gear reduction motor that is used to slowly turn fishing rods after you epoxy on new guide rings. Keeping the rod rotating slowly, about 12 rpm I think, keeps the epoxy from running to one side of the rod until it is dry. The first thing that popped in my head when I saw it was using it to finish pens. I may have to "borrow" it and give it a try. They're plentiful and relatively cheap on E-Bay and available in different RPM ratings as well. Just a thought.
Bookmarks |
Thread Tools | |
Display Modes | |
![]() LinkBack to this Thread: http://www.penturners.org/forum/f28/life-after-ca-72065/
Posted By | For | Type | Date | |
looking for very high gloss pen finish - Woodworking Talk - Woodworkers Forum | This thread | Refback | 01-14-2012 10:14 AM |
