emsmith
I have been using only Hut Crystal Coat as a finish on my pens. After reading about lacquer I decided to try it and purchased a can of Deft high gloss spray. I applied it to the blank, with the blank spinning at the medium speed on my Jet Mini. First coat went on smooth. Applied the second coat and got serious orange peel effects. How do I remove the lacquer? I originally let the lacquer cure overnight and tried to smooth it out with 1000 grit wet/dry sand paper at medium speed, planning to add more coats to build up the finish. The sand paper loaded up and didn’t seem to be removing much material, so I went to progressively coarser grit until I ended up at 220. Which removed the finish, except for these rings of gummy finish, which I removed by sanding along the length of the blank. I start trying to work my way back up through the sanding grits and the rings reappear. I’m using fresh sandpaper and the blank appears to be clean of the lacquer. If it matters the blank is a stabilized brown box elder burl. What am I doing wrong/missing? I don't think it should be this difficult to remove the lacquer. I'm trying to keep the sand paper from both from laoding up and getting warm so I don't think it is a heat problem, but I have no experience using lacquer. All help/suggestions is greatly appreciated.
Thanks,
Eric
Thanks,
Eric
