Jack Daneils Finish
Arbetlam
Auburn Hills Mich.
This is the first time i have turned a Jack daniels blank and I was wondering what kind of finish to put on the finished blank. I normally do the CA finish and do the MM. With these blanks though you can actually smell the whisky residing in the blank. What I was wondering is there a finish I can put on this blank that would give a semigloss finish and still allow that oodor to come through?
WillinSEMN
Minnesota
I've turned a couple of pens from these blanks and they turned out well (PSI Guardian Jr. kits).
Although the blanks smell very good while turning them by the time I had them turned down they didn't retain much aroma. I finished with shellawax and the finish was nice.
CREID
Vancouver, wa
Pretty much anything that seals the surface will seal away the aroma. I am currently trying to figure out how to do the same thing with wine corks, haven't been able to find anything though. Well except, not using any finish at all. This would allow the aroma to come out, at least as long as until it takes to fade away over time. This would also allow the oils from the fingers and such to turn the blank black, which some people may find desirable, a patina type thing you know. If you find a way to do this, let me know.
Curt
Arbetlam
Auburn Hills Mich.
Thanks for the ideas. I like the idea of the cutoff in with the pen. I have been commisioned to do a sculptered set with the pen, letter opener, and magnifing glass. All this will be in a display case so the cutoff is looking like the ticket.
Creid: LOL they would just drink it!
Charlie_W
Sterling, VA USA
Remember to sand your cutoff as you would for a pen. No saw marks, no sharp edges.
larryc
Mableton, GA (Near Atlanta)
I've sold a lot of these and this is the way I finish them.
When I buy the blanks they have a black side to them from the charcoal treatment of the barrel.
After turning to size and sanding through 12,000 micro mesh, the charcoal is gone so I put the blanks on a mandrel, align the grain (if a two blank pen) and with small torch singe a streak on the blank.
I tell my customers that I don't put any finish on those pens in order to retain the "flavor" of the wood.
As the pens sit on my display (in a Jack Daniels coffee cup) they lose their aroma and I use a perfume applicator to restore the flavor. I will do this after a customer has sniffed the pen and says he (or she) doesn't smell anything so that they can see how to restore the aroma after they have purchased the pen. I keep one of those airline size bottles of Jack available so I can show them that it is the real thing.
CREID
Vancouver, wa
Seeeeeee. I knew it would be a good idea to use a perfume thingy.:tongue:
Curt
CREID
Vancouver, wa
Just another off the wall idea here. Clean the area around your lathe real good so you won't get any contamination. And then turn your blank and save the shavings so you can put them in the pen box, maybe lay the pen on a bed of shavings. It ought to have a real strong aroma for awhile.
Curt
Lathrop, CA
I just wanted to say thank you to the OP for asking the question and everyone's response. I am doing a PSI Gatsby Grande with the Jack Daniels and never thought about how to retain the smell.
Sabaharr
Slidell, LA
I recently visited the Jack Daniels distillery (last month) and bought several used barrel staves from the barrel shop. Each one is branded with the JD logo and I selected the ones with the most distinct stain line from the whiskey going about half way through. I am wondering if I will get tipsy from the fumes when I cut them up and turn them as they are very potent. I can smell them in my little shop sitting in my special wood pile. Shavings and a piece of blank cutoff is a great idea and a spritz of JD just before delivery is icing on the cake. Now I just have to make myself cut them up. I have a pic of myself at the distillery propped up against the statue of Jack that shows I was there so it can authenticate my claim of origin of the wood. I highly recommend the tour if anyone gets a chance to go, but it is off the beaten path. It is very popular with the tour bike crowd also. (Side note: The JD bar-b-que hamburger is heaven on earth). Thanks for the ideas.
Krash
Albuquerque, NM
I have thought about how to add a scent to the finish. I was going to try to supply pens to a local lavender farm store and thought since I use a BLO/CA finish that possibly I could replace the BLO with lavender oil. I haven't tried it yet but maybe you could give it a go with something like this:
Kentucky Bourbon Fragrance Oil
I would love to hear about your results!
Skie_M
Lawton, Ok
For adding flower scents in general, you can use (SPARINGLY) some essential oils mixed in with your BLO or other finish components. Some essential oils can be extremely strong, like peppermint oil or jalapeno oil, but some will surprise you with how powerful they are, like orange oil and lemon oil.
Sabaharr
Slidell, LA
Kentucky Bourbon on Tennessee Whiskey. Good Lord man that is sacrilege. You might as well break Jack's other big toe. (FYI: Jack Daniels died from a broken toe from when he kicked his OLD #7 safe when it would not open).
DigBaddy72
New Holstein, Wisconsin
I usually put the shavings in a ziploc bag and put the pen in the bag as well. The aroma from the shavings is pretty strong and that way the customer can get a whiff whenever they want.
Skie_M
Lawton, Ok
I think it would be interesting to take a perfume applicator foam tip and a small glass vial and fill it with jack daniels .... and then conceal it inside the pen. It will probably evaporate out and wear off within a week, but think about the opportunity ....
You can give the pen as a gift along with a bottle of Gold Medallion Single Barrel Jack Daniels "Finest" Whiskey... they can keep that little vial full for a while, and you can join them for a drink just for old time's sake.
rduncan
Albuquerque, NM, USA.
I must have bought old blanks because I get very little aroma, if any, when I turned the first couple. Mine are going to be gifts so won't need to impress anyone with the scent but still......
Jgrden
hOUSTON, Texas
Curt
I have made allot of wine cork pens. The method to make the cork stable seals the wonderful odor. I like the idea of including a piece of stained cork with the original cork.
