george
Thanks Butch,
2 more questions then I'll start practicing...
1. Is there any particular ca I should use? Seems like medium would be a good start, and just let it dry and build it up with a few coats--no accelerator--just patience...then sand progressively.
2. Is micromesh and water to develop a slurry good enough to get the shine or do I also need to use a plastic polish to get that last scratchless shine?
Thanks,
Steve
I do not like thin CA ... medium and thick works better for me. I use accelator every second coat ... the key is to make thick CA layer, but as smooth as possbile. You can put on 15 layers, but if you end up with rough surface that needs lot of sanding, you did not make much .... you will come through the CA at least on one spot and then you must go from start.
