How to properly clean MicroMesh, if at all? - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 06-28-2018, 01:47 PM   #21 (permalink)
Woodchipper's Avatar
Photos: 1
Default
What TonyL said.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 06-28-2018, 01:59 PM   #22 (permalink)
Rifleman1776's Avatar
Photos: 0
Default
I put in a little mesh bag and toss in with the laundry. BTW, I have never used wet and never before heard it should be. Dry works for me. I have two sets of mm, first has been used for years, haven't needed the second and doesn't look like I will have to for a long, long time.
__________________
Frank
Mountain Home, Arkansas
"All animals are equal, but some animals are more equal than others." from Animal Farm by George Orwell
Rifleman1776 is offline   Reply With Quote Top
Old 07-05-2018, 11:43 AM   #23 (permalink)
bradh's Avatar
Photos: 3
Default
Nobody mentioned how to clean micromesh if you dry sand, maybe I am the last one left doing this, lol. Wipe the MM on denim and it pulls most of the dust out of the pads. I have a piece of denim from an old pair of jeans; I sit this on the ways while I sand. Wipe the pad down during and after. Every 10 pens or so the pads need a wash in soapy water for a better clean.
__________________
Brad Harding
Harding Pens and Woodturnings
www.HardingPens.ca
Aurora, Ontario, Canada
....Exposing the beauty that God weaves into wood
bradh is offline   Reply With Quote Top
Advertisement
Old 07-05-2018, 04:51 PM   #24 (permalink)
Rick_G's Avatar
Photos: 30
Default
The other part of your question, is it worth it? I didn't think so and gave up on micromesh. I wet sand with 2000 grit automotive sandpaper then plastic polish. I find a 4" long by 3/4" strip will last me several pens, I'll wet sand at about 1000 - 1500 rpm for a short while then dry the blank and look for any shiny spots, if there are any a sand a little longer. Between each session I just put the sandpaper in a container of water and clean the slurry off with my fingers. After I'm finished I just leave it in the water.
__________________
Rick
I support
The Pens for Canadian Peackeepers Project
http://www.undergroundwoodworking.ca
Rick_G is offline   Reply With Quote Top
Old 07-22-2018, 12:34 PM   #25 (permalink)
Photos: 0
Default
Could this be why my turned wood is turning black with the Micro mesh?
Sallybarden is offline   Reply With Quote Top
Old 07-22-2018, 12:35 PM   #26 (permalink)
Photos: 0
Default
Quote:
Originally Posted by eharri446 View Post
I use a spray bottle with water and a drop or two of dish detergent to breakdown the surface tension. I clean my MM under running water with a little dish soap. I then lay them on a towel to let them air dry.
I was recently given a tray for holding my MM pads which has the grits engraved where each one will go, and a small area for holding water.
I have used MM on wood dry and it will do a good job, however, you have to have a light touch or you will bond the grit backing onto your blank. You have to clean your pads more often.
Old 07-22-2018, 01:28 PM   #27 (permalink)
JimB's Avatar
Photos: 11
Default
Your problem could be contacting the bushings with sandpaper/micro mesh and getting fine metal sanding dust onto the wood.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
