Dario
I had Cherry pen finished with 5 coats of Tung oil. It properly cured but while buffing (using Turtle car polish - paste that looks like white diamond), I can't seem to reduce the application lines I have. I tried 2000 grit sandpaper instead and guess what, I went back to almost bare wood on some places!
VERY bad move... since the finish is almost perfect to begin with.[V]
I ended up taking everything out with 0000 steel wool and re-applied a fresh coat of Tung oil last night.
Next time around...what should I use to buff it? Lathe speed recomendation will help too
Thanks!!!
Thanks!!!
