How to... - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 09-22-2014, 03:53 PM   #1 (permalink)
Photos: 5
Question How to...
Hey all.
I have a problem, and am hoping that someone here has run across it and fixed it at one point or another.
I'm still a mandrel turner (can't afford to replace my stock with TBC bushings).
ANYWAY...My issue is with CA finishes. I'm trying to figure out how to take the blank off the bushings without destroying the end of the CA finish. Essentially when I cut the bushing off the blank, it bubbles the end of the finish and ruins the hard work. Prior to cutting it off, it looks perfect!
I have attached a picture for an example. Any help that you can provide would be much appreciated!
Trey is offline   Reply With Quote Top
Old 09-22-2014, 04:01 PM   #2 (permalink)
Photos: 0
Default
When I first started making pens and finishing with the bushings on, I would cut through the CA with a box knife at the bushings. Now I finish sand and CA with the delrin (or whatever they are made of) tapered bushings. I'm also more careful of not running too much CA glue over the ends.
Rodnall is offline   Reply With Quote Top
Old 09-22-2014, 04:02 PM   #3 (permalink)
Photos: 0
Default
Also, next time that happens, put a little CA glue on the ends and refinish before you assemble.
Advertisement
Old 09-22-2014, 04:09 PM   #4 (permalink)
Photos: 26
Default
its been a while since I turned with a mandrel so i'll pass on that part but I will say that its happened to me more timed then I care to think about. I turn between centers with my stock bushings so theres no need to replace the bushings you have. a dead center will set you back less then you spend on some of those kits. well worth the change over.
paintspill is offline   Reply With Quote Top
Old 09-22-2014, 04:16 PM   #5 (permalink)
Photos: 0
Default
When I did it I put a little johnsons floor wax on just the ends of the wooden blank and they seemed to not stick to the bushings. Just the way I did it, not saying it is the only or even the best way FWIW. Dennis
Olsarge is offline   Reply With Quote Top
Old 09-22-2014, 04:23 PM   #6 (permalink)
Banned
Photos: 0
Default
Several already posted ways...but...wax the bushings before you start turning, tap on a hard surface...your choice, use Delrin bushings for finish, they have nothing to do with mandrels.
Jim Burr is offline   Reply With Quote Top
Old 09-22-2014, 06:17 PM   #7 (permalink)
BURLMAN's Avatar
Photos: 10
Default
+1 on all the above comments. Before I started using delrin bushings, whenever my steel bushings stuck to the blank, I would use a disassembly rod to tap them out. Never had a problem.
BURLMAN is offline   Reply With Quote Top
Old 09-22-2014, 06:21 PM   #8 (permalink)
Dan Masshardt's Avatar
Photos: 0
Default
Option 1 : buy the delrin cone bushings with the mandrel hole through.
Option 2 (what I do). Apply ca on centers between centers with no bushings for this stage.
Dan Masshardt is offline   Reply With Quote Top
Old 09-22-2014, 06:25 PM   #9 (permalink)
RKB
Photos: 0
Default
My wood blanks looked like that before, I thought is was moisture getting in between the CA and the blank. I stopped wet sanding wood blanks.
RKB is offline   Reply With Quote Top
Old 09-22-2014, 07:08 PM   #10 (permalink)
JohnU's Avatar
Photos: 2
Default
I switched to the cone delrin bushings. You get 4 in a pack and they fit any size tube because they are tapered, and clean up easily by dropping in a jar of acetone.
Another tip, I don't know what kind of wood that is, but when I use oilier woods like rosewood or cocobolo, I always make sure to wipe the blank down real good with denatured alcohol to remove the surface oil. I do this until the rag comes off clean with no oily discoloration. Just make sure to let it dry for a few minutes before adding glue or your glue will turn white from the moisture. It will allow your glue better adhering to the wood and maybe cut down on the potential of the finish lifting.
JohnU is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
finishing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
