Homemade "UltraShine" Grrrrr
Spinzwood
Santa Rosa, CA
I was watching a few YouTube videos where turners made their own sanding wax. Essentially, the formula was 4 parts mineral oil, 1 part tripoli and one part beeswax. I did this by weight. 6 oz, 1.5 oz and 1.5 oz.
Formulation was easy.. but, I got horrible results in my one trial on a light colored piece of alder (I think it was alder). Anyhow as you can see in the photo, the sanding wax left dark gray color in the wood.. not what I was expecting.
The guys that made the SW on YouTube had a tan colored tripoli and mine was a dark gray color. I ordered it from Amazon and it was listed as Rottonstone/Tripoli. It was made by Behlens which I remember as a reputable manufacturer of wood finishing products and was listed on the container for finishing woodwork that has a finish applied.. such as a varnish.
So, not what I expected.. Have any of you made your own sanding wax? If so, what did you use for the grit?
Edit: I later saw a formulation by Capt'n Eddie. He used beeswax and mineral oil without the tripoli. I'm guessing this is likely what I should make up. Probably use the mix with the rottenstone for putting a polish on items that have already had a hard finish applied. Wonder if it would work with acrylics.. which I have yet to try..
leehljp
Member Liaison
Tunica, Mississippi,
That photo and the resulting "grayed" polish make it look like bamboo!
Thanks for the note on mineral oil and bees wax. I have tried other versions over the years but I don't think I have used that.
Spinzwood
Santa Rosa, CA
Definitely not bamboo.. I'm quite sure it's alder.. Re the beeswax and mineral oil, that's Capt'n Eddy's formula that he got from an old time turner friend of his.
Because of the mineral oil and beeswax, I doubt one could put a finish on it other than shellac.. but, possibly something harder over that if desired.
donstephan
Cincinnati Ohio
What is the objective - are you trying to get a smoother surface on raw wood prior to applying a finish, get a smoother finish on wood that will only get mineral oil, fill pores before applying a finish, . . .
If the first, adhesion will be an issue over wax and mineral oil; if the second, plain 800 grit sandpaper gives me an extremely smooth raw wood surface; if the third the filled pores will never dry hard.
nava1uni
San Francisco, CA, USA.
I make my own wax for all items that will be used in the kitchen for eating or with food. I use 1 oz of bees wax to 8oz mineral oil. I heat it in a double boiler on low heat and then dispense it into containers. I also use it when sanding those items. You can also replace the mineral oil with pure tung oil. That is then a finish polish
dogcatcher
TX, NM or on the road
The only times I use rottenstone is after a finish has been applied and cured. Then I mix a little with mineral spirits or mineral oil and hand polish with the mixture, it was like the wet sanding process like auto painters do on the clear coat.
I only use the mineral oil and beeswax combos as a finish for food safe items. That mineral oil comes from the pharmacy. Way back when I made homemade wood spoons and forks, I kept 2 crockpots with the mineral oil and beeswax mixes I them, I would turn on the pot to warm the mix to soften the wax and make the mineral oil a little less thick. One crockpot had more wax in the ratio than the other. I used clean cloths to apply the mix, this was my personal preference as to how I applied it, others dipped or tried to "soak" the wood.
monophoto
Saratoga Springs, NY
Daniel Villarino posted a new video this morning on making homemade abrasive paste. He appears to be using a 'blond' tripoli, but he doesn't mention that there is a choice of colors. He does mention use of abrasives other than tripoli.
I have never tried making my own abrasive paste. I have used a commercial product (Dr. Kirk's). But - - - I have a fundamental concern about using a paste containing both wax and mineral oil on raw wood because I normally finish my pieces with an oil finish. Instead, I have used abrasive Dr. Kirk's as a polishing compound applied over a fully-cured oil finish - one that has been allowed to cure for several weeks. My experience with Dr. Kirk's (which is very white) has been excellent. It would be interesting to see if a colored abrasive wax would produce a similar effect, or if the piece would retain some of the color.
There are a number of videos from British turners who use Yorkshire Grit - which appears to have a brownish color.
Spinzwood
Santa Rosa, CA
Thanks guys.. I think Daniel is where I might have found the recipe.. although it appears that video was uploaded today. He may have found another YT video.. which may have been what I originally saw and just ordered materials. I didn't realize this tripli was dark gray.. arghh.
That said.. watching Daniel's video and his description of the tripoli he uses.. I'm guessing what he is using is diatomaceous earth.. which is roughly the color of what I have seen. It is made from the ground remains of microscopic sea critters. It can be found at pool supplies for pool water filtration.. it's very fine. Until the video he posted.. I would not have thought of that.
Surprise, Arizona
Just so you know, the paste you made is fine for a CA finish or acrylics. I did the same thing after watching Daniel's original version. I ordered tripoli from Amazon without knowing it was the dark stuff...
I use the paste after sanding to 2400 MM (the third pad) then polish with Novus 3 & 2. It's a real time saver vs using all the MM pads and I can't see a difference under 10x magnification. I have pumice powder and will make a paste to see if I can eliminate MM altogether.
Surprise, Arizona
Not sure about using pumice. It is VERY course
Yes, but Hampshire Sheen has both pumice and rottenstone, and pumice is also one of the steps used in a hand rubbed lacquer finish which I've done many times. I figure if it cleans up sanding from 400 grit, or hopefully even 320, then I can eliminate all the MM pads. On my first batch I'll use half what I use for my tripoli paste then I'll test it and adjust from there. I'll post results with pics after some trial runs.
avramw
Can you use this under CA finish?
Anybody know if you can use any of these homemade recipes or EEE to sand the wood after 400 grit and get it really smooth before applying CA glue as a finish? Do you think it would react with the glue or cause it to not adhere well?
