homemade friction polish
lkorn
Virginia Beach, VA, USA.
Mike, it has the same durability as the HUT FP, not much. Russ FAirfield aslo has a recipe for homemade Fp on his website. However even better is his recipe for a lacquer based FP. There are also commercial lacquer-based FP on the market. We used some at the Grizfest on both my corncob, and the bottle stoppers Griz made.
Originally posted by MDWine
<br />I wonder how durable it is? Shellac is still shellac, right?
Drums, PA, USA.
DNA is the standard alcohol used, but, you can use moonshine if it's cheaper.[8D]
Shellac can be very durable if used properly. There are 300 year old violins still around that used shellac as a finish.
wayneis
Okemos, Michigan, USA.
Larry what is the name of that commercial FP? I'm starting to do a few small things that it would work on real good I think. If only Griz were here he would know too.
Thanks,
Wayne
lkorn
Wayne, I'll check when I get home and tell you tomorrow.
Originally posted by wayneis
<br />Larry what is the name of that commercial FP? I'm starting to do a few small things that it would work on real good I think. If only Griz were here he would know too.
Thanks,
Wayne
vick
Gilbert, AZ, USA.
http://woodenpost.com/products/liquid_friction_polishes_and_sealers.htm
Here is a link to a Lacquer based friction polish. I have never used it before though.
GregD
Marion, OHIO, USA.
Here is a "Home Brew" That I have been using. I copied from this site when I first joined. I've also been using more shellac than it calls for. It seems to work better.
"Home Brew"
1 unit Shellac (3)
1 unit Denatured Alcohol
1 unit Boiled Linseed Oil
2 units Mineral Spirits
When I use "unit" I mean, unit of measure (tbs, pint, quart, etc.) and I often just use a coffee scoop as my measuring cup, so it would be 1 scoop shellac, 1 scoop alcohol, 1 scoop BLO, 2 scoops mineral spirits.
I dampen a cotton cloth with the solution and hold it against the barrels still mounted on the mandrel and spinning with the lathe set to High Speed and hold it on there until the cloth is dry. This leaves a real nice glossy finish
lkorn
Wayne,
This is the stuff, tis a good thing Billy posted the link, because I got busy with other things last night and forgot about checking it out.
Originally posted by alamocdc
<br />The lacquer based FP that I've seen Tom (OldGriz) recommend is Turner's Magic. Here's the link: http://www.woodwriteltd.com/turnmagi.htm
GregD
Marion, OHIO, USA.
All this talk about friction polish got me motivated enough to go buy some lacquer and lacquer thinner. I mixed 1TSP lacquer, 1TSP thinner, and 1TSP Blo. It gave the same great results as shellac but should be a lot tougher than the shellac.
Thumbs
Muncy, PA, USA.
GregD, when you made your lacquer based FP you said you used more than the recipe called for. There is a #3 behind the shellac on your "recipe" line. Is that the multiplier you used?
And how about giving us some feedback on your lacquer based FP as to durability and shine after you test it for a bit. I love my "Mylands" but it's also awful expensive. This sounds like a possibly great alternative! Thanks!
GregD
Marion, OHIO, USA.
Originally posted by Thumbs
<br />GregD, when you made your lacquer based FP you said you used more than the recipe called for. There is a #3 behind the shellac on your "recipe" line. Is that the multiplier you used?
Bob,
Yes, the 3 is the multiplier for the shellac. You may want to play with it. This is just what I found works for me.
Yes, I will report on the durability and shine of the laquer FP.
Fred in NC
LANDIS, NC, USA.
Shellac is flakes dissolved in DNA. The usual way to describe it is in "pound cuts."
A pound cut means one lb of shellac flakes in a gallon of DNA, 3 pound cut means 3 lbs of shellac in a gallon of DNA, etc.
melogic
Ironton, Ohio, USA.
Thanks Greg for all of this wonderful info. I just turned a cushion grip pen out of Dyamond wood and used this brew just a you stated and I can't beleive the acrylic-like finish it gave me. My wife is hooked on this and she is ready to turn more pens just to finish them. I did put a top coat of TSW just to get the slick finish and protection. As soon as I can get a good photo to show off the shine I will post it here. Thanks again!
GregD
Marion, OHIO, USA.
That's good Mark. I'm glad I could help someone. I've got to get some TSW. I haven't tried it yet. Too many other things need my money.
MDWine
Manassas Park, Virginia, USA.
GregD!! I'm intrigued with the 1 part lacquer/ 1 part thinner/ 1 part BLO mixture. Did you apply this just like a friction polish? Lathe running? Did you need to sand/MM/buff afterward?
I think I'd like to try this one. Would you like to give us a few more details about how you applied it and how it finished? (I, for one, would really appreciate it!)
TIA!
GregD
Marion, OHIO, USA.
Mike,
Yes, I applied it just as I would friction polish with the lathe on. I'm not really happy with the finish. I thought it would have more gloss.I'm still working on it. I guess the next step is MM or buffing.
Thumbs
Muncy, PA, USA.
OK, now I'm gonna reveal how ignorant I really am! What happens when you mix a lacquer base finish with a shellac based finish? Does it turn to crud? Never dry? Explode and burn? Anybody admit to ever trying this?[?]
Stop Laughin'! Just tell me!
GregD
Marion, OHIO, USA.
<br />OK, now I'm gonna reveal how ignorant I really am! What happens when you mix a lacquer base finish with a shellac based finish? Does it turn to crud? Never dry? Explode and burn? Anybody admit to ever trying this?[?]
It pretty much turns to crud, as you put it.
melogic
Ironton, Ohio, USA.
Bob I used the shellac based finish just as stated in Greg's earlier post. I put 3 scoops of shellac, 1 scoop of BLO, 1 scoop of Denatured Alcohol and 2 scoops of Mineral Spirits. The Finish is the highest gloss I've ever had on a pen and it looks like I glazed the wood with clear plastic or something. I applied it by just touching the corner of a cotton cloth in the mixture and holding it on the pen as it was turning on my lathe until the cloth was dry. Then I used a clean part of the cloth to buff the blank and then I applied a coat of TSW. My wife and daughter turned about 5 or 6 more pens this evening and they look fantastic. As soon as I can get a picture to show the gloss I will post it here.
melogic
Ironton, Ohio, USA.
Here is a picture of the cushion grip pen I turned and finished with the shellac brew.
<br />
Thumbs
Muncy, PA, USA.
Thanks, Mark! I've used Crystal Coat, Shellawax, and Mylands Shellac based FP's. The Mylands seems far superior to the others so the proper mix is apparently the important part. If you look at the way the solutions separate after standing for awhile, it is quite apparent that the solutions contain differing quantities of the various substances. I just don't know which is which![:)]
Thumbs
Muncy, PA, USA.
That was fast![:0]
<b>Mark</b>, I know this may sound silly but could you also post a picture of your solution in a bottle so I could see how it separates proportionally? I know, just a big PIA! <b>BTW</b>, that looks very similar to a Mylands finish![:p]
Another <b>BTW</b>: With Mylands it still seems to work best if you let "cure" a couple days before you handle the pens very much........ FWIW
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
Originally posted by melogic
<br />Bob I used the shellac based finish just as stated in Greg's earlier post. I put 3 scoops of shellac, 1 scoop of BLO, 1 scoop of Denatured Alcohol and 2 scoops of Mineral Spirits. The Finish is the highest gloss I've ever had on a pen and it looks like I glazed the wood with clear plastic or something. I applied it by just touching the corner of a cotton cloth in the mixture and holding it on the pen as it was turning on my lathe until the cloth was dry. Then I used a clean part of the cloth to buff the blank and then I applied a coat of TSW. My wife and daughter turned about 5 or 6 more pens this evening and they look fantastic. As soon as I can get a picture to show the gloss I will post it here.
The finish on the pen looks great... my question is how does it hold up... shellac finishes are not known for durability...
Have you done a pen with that finish and used it for a long while to test the durability...
I am not trying to be a Wise Guy, we all know that the finish will sell a pen... but the durability will keep the customer happy and make him refer others back to you..
Fred in NC
LANDIS, NC, USA.
Tom, I have the same concerns about shellac. I use it only as a sanding sealer.
However, if the wood is highly polished before the shellac based friction polish is applied, it will get a natural finish or patina. See Russ Fairfield's comments on this.
alamocdc
San Antonio, Texas, USA.
Greg, I've been using the same "lacquer" based FP you made up and have experienced a rather wide variety of finishes with it. I always use a lacquer sanding sealer in the sanding process and MM to polish the barrels prior to applying the FP. Sometimes I get a rather satiny finish, sometimes a get a semi-gloss and sometimes I get a high gloss, but I have yet to achieve the kind of high gloss I get with Mylands. I don't know if the type of wood makes the difference, or if it may be the number of coats applied and the time between them. I'm still experimenting with that right now, but it apprears that at least 3 coats with about 30 minutes (15 minimum) between them yields the best result for me. As for durability, the jury is still out, but it appears that this will be considerably more durable than my other FPs. Provided it is allowed to cure properly.
melogic
Ironton, Ohio, USA.
I was wondering the same thing that Tom is saying, "How long will it last?" I would have thought shellac would last a long time, but I don't know a lot about the durability of the finishes.
