Help on finishing please... - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 09-04-2017, 01:31 PM   #11 (permalink)
Photos: 0
Default
How do you apply it to a pen sanded with eee?
dariot is offline   Reply With Quote Top
Old 09-04-2017, 01:54 PM   #12 (permalink)
JimB's Avatar
Photos: 11
Default
I've never applied it to a pen sanded with EEE. I sand the pen to the desired grit and then use a very small piece of paper towel to apply the WOP. Thin coat, let it dry/cure, lightly rub with a very fine sandpaper or 0000 steel wool to remove any bumps and then apply another coat. Repeat as many times as you want. Each coat will go on smoother than the previous one. I do all that off the lathe so I don't worry about how long each coat takes to dry. I usually let it dry for 24 hours.
It's very easy to do. No tricks or special technique required.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 09-04-2017, 03:22 PM   #13 (permalink)
Woodchipper's Avatar
Photos: 1
Default
Nitrocellulose? The base material for smokeless gunpowder.
__________________
Due to the lack of interest, tomorrow will be cancelled.
Woodchipper is offline   Reply With Quote Top
Advertisement
Old 09-04-2017, 04:44 PM   #14 (permalink)
Photos: 0
Default
I go back & forth between Woodturner's Finish and CA. For WTF, I apply with a scrap from an old white t-shirt. I can usually use the same applicator 3 or so times before it gets too brittle to re-use. The 2nd and 3rd pens are usually the best. After applying, I have to walk away for 8 to 12 hours to let it cure, then buff with another old t-shirt and finish by burnishing with a scrap of brown grocery bag. CA on the other hand, I apply with white paper shop towel cut into about 2" squares.
Both have been working for me--probably more luck than anything, it is sure not experience.
earl
greenacres2 is offline   Reply With Quote Top
Old 09-04-2017, 05:48 PM   #15 (permalink)
KenV's Avatar
Photos: 0
Default
Dario---
Much of the materals and techniques of wood turning and pen making are borrowed and adapted from other industries and technologies. While the brands differ from country to country, the basic components are around to be adapted.
There is another thread running about a product sold as automotive clear coating. (KMS Diamond). Lacquer is used in a similar manner as luthiers use on musical instruments or furniture builders use. The buffing of pens is based on metal work industries.
Look around for sources.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 09-05-2017, 02:24 PM   #16 (permalink)
Photos: 0
Default
Ok thanks
Last question... Bog oak... Better finish it or leave it as it is?
Old 09-05-2017, 03:23 PM   #17 (permalink)
magpens's Avatar
Photos: 63
Default
I would say that you should apply a finish to bog oak .... what ever finish works for you.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is online now   Reply With Quote Top
Old 09-05-2017, 04:13 PM   #18 (permalink)
Photos: 0
Default
Thanks!
Old 09-05-2017, 04:14 PM   #19 (permalink)
Photos: 0
Default
Many thanks
Old 09-05-2017, 10:15 PM   #20 (permalink)
mmayo's Avatar
Photos: 0
Default
General finishes "wood turners finish" is easy, non toxic compared to CA, cheap and shine up nicely. Tough finish, check the blue paper towels after applying it - they are rock hard in an hour or so.
I use it for my non-CA coated pens.
__________________
Mark Mayo
Kites rise highest against the wind, not with it.
Winston Churchill
mmayo is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
