Help! CA finish on Olive Wood - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 06-27-2017, 02:59 PM   #1 (permalink)
DJBPenmaker's Avatar
Photos: 0
Default Help! CA finish on Olive Wood
I'm having trouble getting the CA to adhere on a pen i'm turning. What's happening is that after application the CA is detaching from the edge of the blank post turning and finishing, causing semi transparent white clouding in parts right at the edges of the finished section/ cap. I used denatured alcohol to clean and de-grease and allowed the blank to dry fully. I'm wondering if i'm getting too smooth a finish with my turning (as you know Olive turns super smooth) and that's causing the CA to detach from the Olive Wood without sinking into the wood. Incidentally I used a first coat of Superthin CA so that it would penetrate the surface easier.
Others must have had the same problem and I'm wondering what the solution might be.
Any help and suggestions appreciated.
DJBPenmaker is offline   Reply With Quote Top
Old 06-27-2017, 03:20 PM   #2 (permalink)
firewhatfire's Avatar
Photos: 14
Default
clean the blank repeatedly with acetone before finishing. this is to remove excess oil from it
__________________
I shall pass through this world but once. Any good therefore that I can do or any kindness that I can show to any human being, let me do it now. Let me not defer or neglect it, for I shall not pass this way again.
― Stephen Grellet
Deuteronomy 31:6
Romans 14:8
firewhatfire is offline   Reply With Quote Top
Old 06-27-2017, 03:29 PM   #3 (permalink)
New Member Advocate
Edgar's Avatar
Photos: 23
Default
You should be able to gauge how oily the blank is when you drill it for the tube. If the shavings are crisp and come off the bit freely, the blank is pretty dry; however, if they are a little sticky and don't come off the bit freely, then it still has a fairly high oil content.
If the blank is quite dry, CA will adhere without much problem; however, if it is still fairly oily, you will need to spend extra time trying to get it dry enough for a good CA finish as Phil suggested.
I sometimes use a CA finish on olive wood, but generally just on very dry blanks. If the blanks are still somewhat oily, I usually just finish with a friction polish.
__________________
Eat pecans - 10,000,000 squirrels can't be wrong.
Edgar is offline   Reply With Quote Top
Advertisement
Old 06-27-2017, 03:46 PM   #4 (permalink)
The Falcons Quill's Avatar
Photos: 0
Default
I would suggest after turning close to final size, that you place the pens to the side to dry out more, the olive wood holds a lot of moisture even after sitting out for quite a while. Then turn to size later. The oil nature does tend to cause problems with CA but the suggestion of Acetone is an interesting idea.
I personally use Renaissance Wax to satin finish Olive wood, i know it doesn't last as long, but on sierra kits, the owner wont be holding on to the wood itself
__________________
Shane Wieman
www.TheFalconsQuill.com
The Falcons Quill is offline   Reply With Quote Top
Old 06-27-2017, 04:18 PM   #5 (permalink)
elyk864's Avatar
Photos: 1
Default
1. Denatured Alcohol (like you've done)
2. Start with thin CA (I do two coats)
3. Then do coats of thick CA
You shouldn't have a problem with it being to smooth, I micromesh all of the wood I turn before I apply CA and have never had a problem.
elyk864 is offline   Reply With Quote Top
Old 06-27-2017, 04:27 PM   #6 (permalink)
Photos: 0
Default
Thank you all, I've never ever had this problem with any other wood and so a trend is emerging from your replies that it is most likely the oil in the wood causing the problem. I shall try again taking all suggestions on board.
Old 06-27-2017, 05:07 PM   #7 (permalink)
Rolandranch's Avatar
Photos: 147
Default
I've had this problem on other woods before - even very dry non-oily woods. I believe it is the thick CA causing the problem. When I use only thin CA (10-15 coats), I get much better results. I could be wrong though.
__________________
Seth, a 18-year-old learning from the experts.
https://www.instagram.com/woodnotch/
https://www.instagram.com/knot_board/
I Corinthians 10:31
Rolandranch is offline   Reply With Quote Top
Old 06-27-2017, 06:11 PM   #8 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
This is the problem that drove me to using TBC or turning between centers. The breaking away of the bushings, even when scoring the CA to the edge of the bushing to pull the bushing out would cause lifting.
Of course I used acetone to try and eliminate oilyness and increase adhesion, but that was inconsistent at best.
I have never had a problem with lifting/separating of the CA since I started turning between centers. Below is a picture of a drive center that I made from a short aluminum rod. At that time, there were only two fellows that had tried or knew of TBC or even spoke of TBC on IAP. Also, they used several terms to describe it including "mandrelless" and "without a mandrel".
View in gallery
Some history here:
By the way, that ebony pen blank in the background is the one in which CA lifted on three different tries and drove me to start using TBC, which basically started the move to TBC on IAP. Frank "Rifleman" and John Goodin "Johnnycnc" both mentioned in a post that they knew of a pen turner (not on IAP) who turned pens without mandrels. That in itself eliminating that lifting on the ends, as well as other problems. Frank had mentioned this several months prior to my trying it. So, after mulling it over and problems 3 times on the ebony wood pen, I turned the drive center, which was retired after getting one from the Little Machine Shop.
Wow, that was about 10 years ago.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
ca finish , olive
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
