| Finishing It ain't a pen till it's FINISHED! |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
I am continually running into this problem with my CA/BLO finish. I get little patches of foggy spots in my finish. I have tried every variable I can to eliminate the problem but it still persists. There are times when I think I got it right but a few minutes later the foggy patches emerge. I can't figure it out. Here is what I have tried so far...
- I tried CA only and letting it cure between coats - I tried a new bottle of CA - I tried different paper towels - I tried various speeds from 500 to 5000 - I tried more BLO, less BLO - I tried to really get the finish hot as it cured (friction), or keep it cool - I tried it on a wide variety of woods Every once in a while I will have one turn out, but there does not seem to be any rhyme or reason to the issue. I would appreciate any help you can give me. Thanks for your help guys! Dulos |
#2 (permalink) |
Photos:
don't stop....when I put on CA, it starts out clear, turns "foggy" but keep rubbing and it will clear right up..or it should
also if it's one spot, make sure there is no water...sweat, any moisture on that spot
__________________
Stay away from the darker side, and if you start to go astray, let the force be your guide.
#4 (permalink) |
I put a coat of thin CA on first to seal the wood, then I switch to CA/BLO, CA/BLO, CA/BLO... as many coats as I want. CA first BLO second. I never put on BLO to wood first as that runs the risk of fogging the finish... undried oil under the CA.
If you plan to wet sand the finish make sure that you start by dipping the ends of the blanks in thin CA to seal the ends otherwise water from the wet sanding will wick into the wood under the CA and fog the finish. Sometimes if you put on many layers and sand down thru some too much Ren Wax can afix itself to the edge of the layer and look like fog. Very annoying. Apply light and keep the heat down. Hope that helps ![]() ![]()
__________________
Stay safe out there!
Bree What a long strange trip it's been! The 60's will never leave, if we refuse to leave them!! |
#6 (permalink) |
Photos:
One thing I do is clean with denatured alcohol. If the material is oily, like ebony or cocobolo, I use a very liberal amount of DA. Almost to the point of the paper towel dripping with DA. This seems to dry out the outer layer of the wood. Since I've started doing this along with skipping the accelerator, my fogging problems have gone away.
I probably just jinxed myself.
__________________
#7 (permalink) | |
One thing I don't do is use denatured alcohol to clean blanks when applying CA glue for a finish. Water readily dissolves into alcohol (water in air such as high humidity). I use CA glue accelerator which I purchase in the bottles. I really like the aersol for using as an accelerator but use the bulk bottles for cleaning. The accelerator evaoprates quickly and causes no ill effects.
I'm not trying to be arguminitive but just sharing what I have experienced. Do a good turn daily! Don Quote:
__________________
Don Ward aka its_virgil
Wichita Falls, Texas www.RedRiverPens.com www.RedRiverPens.com/articles (pen stuff I've written) |
#8 (permalink) | ||
Photos:
Quote:
__________________
Bob McCormick
Georgia USA |
#9 (permalink) | ||
Photos:
Quote:
I wasn't thinking water was the problem. For me it's been oily wood. And DA has helped. But I also rarely use accelerator anymore as that has been reported by some to be a problem with fogging. So if accelerator helps, I'll start using that to clean blanks since I have a pretty good supply that rarely gets used.
__________________
| Bookmarks |
| Tags |
| blo , ca , finish , foggy |
| Thread Tools | |
| Display Modes | |
