Flexner on Pen Finishes
KenV
Juneau, Alaska.
From one of the masters of finishing ---
Finish for Wooden Pens - Popular Woodworking Magazine
"......So my recommendation for an alternative finish to CA glue is pre-catalyzed lacquer. It also crosslinks. It is sold in small containers by Craft Supplies as "Melamine." The product comes from England, and this is what pre-cat is called there, at least by Mylands, the supplier of the finish. (Catalyzed lacquers are made with melamine.) Here's the link to the product…
You can also buy pre-cat at paint stores that sell to the professional trade, of course. But the smallest size will be a gallon, which is a lot unless you turn a lot of pens.
Be forewarned though that this finish also has fumes, so if you're interested in a substitute for CA glue, this may not work well for you. The solution for fumes is good airflow away from you. You can arrange this easily with a fan.
If the fumes from both CA glue and pre-cat irritate you, even with a fan, you may have to settle for an inferior finish.
— Bob Flexner"
  • Like
Reactions: RKB
low_48
Peoria, IL, USA.
I didn't see where you said anything about precat lacquer in your previous post. You just said lacquer, two very different materials!
Rockytime
Arvada, CO 80003
A bit off the subject but there have been discussions on polyurethane finishes. I do not use it due to drying times. Hanging the blanks causes the finish to be thicker at the bottom of the blank. Someone posted how he finishes arrows with sort of a squeegee affair made from a piece of bicycle inner-tube. PSI has a neat drying device which rotates the blanks slowly. I like that idea but am not willing to spend $60 fora cheap little bar-b-que motor. If I can find one in a thrift store I may make one.
SteveG
Eugene, Oregon 97404
A quick computation reveals that the Myland's lacquer in the link runs $158 per gallon plus shipping. I know there will be differences, but the local pro paint supply can likely provide their formulation of pre-cat (or the close relative which is cat lacquer, where you mix in the catalyzer provided in a separate container) at a better price, if you expect to be using more than the 16 oz can. I have used the "you mix it" variety for a spray on furniture finish with great results...it is really tough stuff, but with all the desirable visual qualities of lacquer.
low_48
Peoria, IL, USA.
I'm not sure a pro paint store will sell catalyst, or even the post catalyzed lacquer to the general public. Many products use an acid base catalyst and are quite dangerous to handle, and dangerous to unprotected lungs. I checked a Mohawk MSDS on post cat lacquer and it carries a level 4 acute toxicity for inhalation. We're talking serious chemicals here!
duncsuss
Wilmington, MA
... polyurethane finishes ... Hanging the blanks causes the finish to be thicker at the bottom of the blank.
Les Elm (rdabpenman) wrote a tutorial on his "polyurethane dipping method". I don't know if he posted it here, but it's definitely in the "Classroom" forum on the Woodbarter.com website.
TimS124
Asheville, NC
Is that this tutorial on that site? The name is slightly different but it sounds like what you meant:
Pen Finish Dipping Method | WoodBarter
duncsuss
Wilmington, MA
That's the one. His user name here is rd_ab_penman, check out his posts in the Show Off Your Pens forum and eventually you'll find several where he says he used his "dipping method". The finish looks great to me.
Wildman
Jacksonville, NC, USA.
Mylands Wood Finishing Products
See the products SDS,
https://www.classichandtools.com/acatalog/Melamine-Lacquer[1].pdf
Have a lot of respect for Flexner & Jewitt both put out outstanding information in their books, articles, &videos.
Friction finishes can be either lacquer or shellac base.
Things you should know before spending your money on pre-cat/post cat finishes. Normally these finishes are sprayed on and have to pay attention to number of coats applied!. You can also find waterbased pre-cat/post-cat finishes.
http://www.woodweb.com/knowledge_base_images/zp/CatalyzedFinishes.pdf
Gist of Flexner's article about speed in application & durability of Mylands pre-cat lacquer for wood turners. You may want to invest in a painter mask with filters if going use that product long term! JMHO, durability of any finishing material on a pen is a SWAG! All about the end user & use!
Rockytime
Arvada, CO 80003
Many thanks for this info. Will try that method very soon. Thanks again.
Hubert H
Wolford, ND
I have been applying all kinds of finishes for 52 years. That is how I made my living. I have used lacquers for over 40 years. My favorite lacquer is the Behlen stringed instrument lacquer for pens and small things. It is a pre-cat that has something in it that is more flexible than the standard pre-cats. It sprays very nice - dries quick and has a nice gloss that can be made any sheen you want with different rubbing compounds. As you will see in the following web-sit it can be bought in quarts. My two cents.
Buy Behlen Luthier's Lacquer, Quart at Woodcraft.com
JoshuaFisher
Kentucky
Just a heads up that isnt actually pre-cat lacquer its just your run of the mill nitrocellulose lacquer, it even states that in the product description, So even though its a really nice product you wont get the same durability of a true pre-cat lacquer
