jedgerton
Ok, this worked once so it must work for all time right?
Have you ever completed one of your best CA finish jobs to date only to find that when you separated it from the bushing, it delaminated? What I mean my delamination is a cloudy area near the end of the finished blank where the CA finish separated from the blank but didn't chip.
Try the following if this ever happens to you, apply thin CA right at the end of the blank where the cloudy region exists. I just tried it and the thin CA filled the gap and made the blemish disappear.
This is only useful if the CA didn't chip and only appears cloudy where the bushing was separated.
I suppose avoiding this issue with delrin bushings would be better but I still use the metal bushings for sanding and finishing.
Give it a try if it happens to you!
John
John
