Finishing with warm water... - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 12-18-2017, 11:27 AM   #1 (permalink)
Herb G's Avatar
Photos: 18
Default Finishing with warm water...
The other day I was finishing some acrylic pens with the Micro Mesh pads.
I used very warm water instead of the ice cold tap water.
I noticed (accidentally) that using the warm water provided a much smoother finish than using cold water does.
My blanks were pretty much finished at 3600 grit, but I went thru all the grits anyway.
When I finished going thru the grits, the acrylic was like glass.
These are the same pads I've used on other blanks, so it wasn't like they were a new set or an old set. I only used them on 4 pens so far.
The blanks were the other 1/2 of a set already made so it wasn't a different acrylic either.
Just the warm water made all the difference.
I thought I'd share something of use to everyone.
Thanks for reading.
__________________
Be happy in your work...Col. Saito
My lathes:
Floor Lathe
Bench top lathe
Herb G is offline   Reply With Quote Top
Old 12-18-2017, 11:30 AM   #2 (permalink)
SCjim's Avatar
Photos: 0
Default
Will try. Thank you.
__________________
Old woodworkers never die, they just keep chipping away!
Jim
Fort Mill, South Carolina
SCjim is offline   Reply With Quote Top
Old 12-18-2017, 12:05 PM   #3 (permalink)
JimB's Avatar
Photos: 11
Default
Very interesting. Thanks for sharing.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Advertisement
Old 12-18-2017, 05:20 PM   #4 (permalink)
More4dan's Avatar
Photos: 5
Default
Iím guessing the warmer water cleans the sanding pads better. If hot water it might soften the plastic a bit. Warm water would sure make it easier to sand in my cold shop. Iíll have to give it a try too.
More4dan is offline   Reply With Quote Top
Old 12-18-2017, 05:28 PM   #5 (permalink)
Woodchipper's Avatar
Photos: 1
Default
Will give it a try. Thanks.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 12-18-2017, 08:40 PM   #6 (permalink)
Photos: 2
Default
I found a couple drops of dish soap also helps.
__________________
Mike
DeBary Florida
burr is offline   Reply With Quote Top
Old 12-19-2017, 03:49 AM   #7 (permalink)
randyrls's Avatar
Photos: 68
Default
Hmmmmm; I remember reading somewhere (one of those "amazing facts") that water actually changes viscosity with temperature. Cold water is more viscus than hot water and with the proper equipment it is measurable.
__________________
Randy S.
Experience, ah, experience; Experience is what you get when you don't have experience!
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 12-19-2017, 08:00 AM   #8 (permalink)
Photos: 0
Default
Going to try it for sure!
Tom1697 is offline   Reply With Quote Top
Old 12-19-2017, 10:05 PM   #9 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Quote:
I used to argue against this, then I went into the industrial water treatment business and found out it was true.
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 12-20-2017, 04:30 AM   #10 (permalink)
Photos: 0
Default
Here in Michigan, warm water is a must to keep my fingers from freezing together. Getting a better shine is a bonus!
__________________
Jeff Miller
www.MillerTurnings.com
MillerTurnings is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
