Finishing suggestions: wood/acrylic segmented blank - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 12-07-2018, 12:31 AM   #1 (permalink)
Photos: 0
Default Finishing suggestions: wood/acrylic segmented blank
Hi:
So Iím trying to make a pen for a friend who served as part of Operation Iraqi Freedom back in the day, and I made a blank modeled after the OIF service ribbon from myrtle, holly and ebony with a red acrylic (Iíve tried to attach a photo of what Iíve turned so far).
My question: would you advise a CA or other type of finish for a mixed segmented blank?
I donít have much experience with finishes except for CA, but I have not applied CA to acrylic - preferring just to micro mesh and apply plastic polish. Also, Iím pretty sure that I have developed an allergy to CA that results in unpleasant cold/sinus symptoms for a day or two. But I just got a respirator with the charcoal canisters so Iím not giving up on CA yet, if thatís the best finish for this blank. Appreciate any suggestions! Thanks, Russ
Sly Dog is offline   Reply With Quote Top
Old 12-07-2018, 12:55 AM   #2 (permalink)
jttheclockman's Avatar
Photos: 84
Default
Quote:
Originally Posted by Sly Dog View Post
Hi:
Hello Russ and welcome to the site.
I like what you have segmented together. I will give you my thoughts because I have segmented some of those woods together and will tell you they will bleed into each other. Here is my way around that problem. I would turn the entire blank with either carbide or a skew or combination and never touch the blank with sand paper. As soon as you start sanding the ebony will bleed into the holy and you will add scratches to the acrylic that you will see when CA over. The stars you do not need to CA because I assume that is all acrylic but if not then same applys to that blank. Yes you can CA over acrylic and in fact that is about all that will stick to it.
Now when starting the finish with CA you need to lightly touch the blank in one sweeping motion and do not rub back and forth with thin CA to seal the blank and keep from smearing the wood colors into each other. It does work.
If it were me I would have chose all acrylic or all wood. Mixing medium like that opens yourself up to different expansion movement. To avoid ridges between the wood and acrylic again the skew is your friend. Those materials turn at different hardness levels so be careful.
Again this is just my opinion. Others may tell you something different. Good luck.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 12-07-2018, 07:44 AM   #3 (permalink)
mark james's Avatar
Photos: 484
Default
Welcome to IAP Russ,
IMO - Yes, a CA is probably merited here.
As mentioned tool skills are crucial to avoid/minimize cross contamination between the ebony and Holly; I fully agree.
However, with care, success is on your side.
This pen blank is Ebony, (not sure of the specific one, but very dark) black veneer and Yellowheart. The Janka hardness of the yellowheart is similar to your holly; both being less dense than any Ebony. The blank was turned with a Magical Skew (a carbide on a 45 degree angle to allow a shear scraping effect) and the grit for sanding started probably around 320 or 400. (I constructed the blanks, EBorraga did the turning). I believe there was 3-4 coats of CA used for the finish.
One final comment: If you are having issues with CA, be very mindful. Once sensitized the problems will most likely get worse with further exposure. Make sure your respirator is well fitted. (My wife, a chemist also encourages me to shave my beard off for a better fit... I've taken that under consideration for the past 6-7 years ).
OH, sweet blanks!
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Advertisement
Old 12-07-2018, 03:33 PM   #4 (permalink)
Photos: 0
Default
Thank you both for those suggestions! I’ve read quite a few posts from both of you in other forums; I value your experience and really appreciate your time answering my question. CA on the lower blank is what I will try. If the pen turns out well I will post a photo in a different forum and see what you and others think.
I get the expansion/mixed media observation and prolly didn’t think that through enough. I would have liked to use all wood but I couldn’t find a wood blank that was red enough to emulate the color of the ribbon. I’ll just have to give my buddy an extended warranty!
Again, thanks gents!
Russ
Old 12-07-2018, 11:19 PM   #5 (permalink)
Photos: 84
Default
Thank you both for those suggestions! Iíve read quite a few posts from both of you in other forums; I value your experience and really appreciate your time answering my question. CA on the lower blank is what I will try. If the pen turns out well I will post a photo in a different forum and see what you and others think.
I get the expansion/mixed media observation and prolly didnít think that through enough. I would have liked to use all wood but I couldnít find a wood blank that was red enough to emulate the color of the ribbon. Iíll just have to give my buddy an extended warranty!
Russ
No problem Russ it should work if you are careful in the turning. As Far as red wood goes. Bloodwood is the redest of woods but it is a deep red. You could always go the dye route on softer woods such as maple or pine. Good luck and look forward to seeing the finished pen.
__________________
John T.
Old 12-14-2018, 08:33 AM   #6 (permalink)
WriteON's Avatar
Photos: 0
Default
Birchwood Casey Tru-Oil. A few applications... It's beautiful and protective. Like anything else...follow instruction and patience.
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool professional pool cue repair lathe
WriteON is offline   Reply With Quote Top
Old 12-16-2018, 12:33 AM   #7 (permalink)
Photos: 0
Default
Quote:
Thanks - Iíve never tried that finish but I will.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
