Finishing With CA Question
TinBarnTurner
Texas
Fairly new at this, but I have turned out some nice looking pens using several different methods.
My main question is when finishing pen blank with CA, I seem to have a problem with the CA sticking the mandrel to the pen blank. Am I applying the CA incorrectly?
I usually apply CA directly to the pen black while it's turning and use a cotton cloth for smoothing.
Using the wrong consistency of CA? I have been using medium. I have ordered some thin CA to try. (Live way out in the sticks so I have to order just about everything I need.)
Someone suggested applying linseed oil to the end of the blank prior to turning. Haven't tried this yet.
Any suggestions from you guys would be appreciated.
thanks in advance,
TBT
Drewboy22
San Antonio, Tx
First off, Welcome to the IAP!!
Secondly, Personally, I would warn you off of using the cotton cloth as well as applying to the blank directly. I have never had any luck applying this way, and the cloth could cause a safety hazard.
I cut a blue paper towel into ~1in strips and put a few drops of CA on the last inch or so of the strip. make one pass down the blank and cut that inch off. Repeat...
I also don't use regular bushings anymore and have switched to "CA Bushings".
Best of luck,
Drew
Notscottish
Boston
I use thin CA and apply with either bathroom tissue or the before mentioned blue shop towels and never apply the CA directly to the blank. I remove the blank from the bushings and turn between centers so I do not have a sticking problem. After every three very thin coats of CA, I spray a touch of accelerator on the tissue and apply to the pen. I get top notch results with minimal sanding.
TinBarnTurner
Texas
All great suggestions. I will definitely try applying the CA with a paper towel. All good suggestions guys.
Thanks for the help and I am really glad I found this forum. I am sure there will be more questions to follow as I move further into this awesome hobby.
TBT
TinBarnTurner
Texas
The closest town to me is Lone Oak. I am sort of east and north of Dallas. Not much around here as far as suppliers goes, but mail order and internet are my friend. We do have a pretty active wood turners club in Greenville.
You do live in one of my favorite cities in Texas. We really enjoy San Antonio when we can get down there.
TBT
MTViper
Clyde, Texas
TBT
Greetings from the Abilene area. I sent you a PM about suppliers in your area ... well "in your area" as in - within easy driving distance in a day.
chartle
Pgh, PA
My Brother in Law lives in San Antonio and the way he describes it it sounds like everything in Texas is 10 hours away from everything else. :)
Drewboy22
San Antonio, Tx
That is pretty much it :) Especially with the traffic in San Antonio, I even have to plan my trips to Woodcraft :biggrin:
Kiwiturner
Hi TBT.
I see a lot of common responses here, and I see these responses often. What it amounts too is that you will eventually develop your own technique.
To help with sticking to the mandrel I suggest you buy a couple of sets of theses. Most suppliers should have them and they are as cheap as chips. Get a couple of sets as spares as they are always handy. Polishing Cones
I put a small video showing finishing the turning of a pen and CA polishing on my website which may be of help.
The CA I use is Starbond . It doesnt get too upset by weather conditions, is extremely consistent in its flow and hardening and polishes out superbly.
I use 3 coats of medium CA to build the base up and then 5 of Thin CA and finish with a plastic polish. End result is a crystal clear high gloss polished finish, which everyone likes, moreso than my wax of oil polish finishes. I guess people just like shiny things.
The video link is here... PP&W
TinBarnTurner
Texas
TBT
Hey, got your PM. Thanks for the information. I am planning a trip to Dallas and will hit the places you suggested. Much appreciated.
TBT
TinBarnTurner
Texas
Hi TBT.
Thanks for the tip on the polishing cones. I think that is exactly what I am looking for.
Appreciate the tip about the thin CA. I think one of the problems I am having may be resolved by the added coats of thin CA. When applying CA, I was only applying three or four coats of medium.
Really appreciate all the responses. It's very helpful when you have a place you can ask questions and get great answers and advise.
TBT
MTViper
Clyde, Texas
There's an old poem my mother used to quote often when we traveled ...
The sun has ris, the sun has set,
And here I is, in Texas yet ...
MTViper
Clyde, Texas
TBT
If you bring your membership card from your turning club, Woodcraft and Woodworld will probably give you a 10% discount. They do for clubs in the Metroplex.
Lubbock, TX, 79423 USA
Finishing Problems
First, how far is it. Our standard answer when some asks how far is it from Lubbock, we say it is 350 Miles.
Next, I find the various methods used to be interesting. Most work. I started out putting the CA on the blank and using one of the little plastic bags that parts come in on my finger to spread it around. That is the method suggested by Richard Kleinhenz is book "The Pen Turners Bible". I now use the paper towel with CA applied to the paper towel. I have never had a problem with blank sticking to the mandrel, but the bushing, you bet. I have tried the non-stick bushings and my CA (Stick Fast) seems to stick to them quite well. And, by the way, I start with thin CA and finish with medium CA with good results. Again from Kleinhenz, there are as many methods of finishing as there are turners. One other suggestion from Kleinhenz I use (especially on open grain woods is to add a few drops of CA to sanding dust and spread it on the blank. Actually I use a slight variation. I use Stick Fast wood finish (slower cure than the standard) thin CA applied to the sandpaper (lathe running at a very low speed) and let it create a slurry as I sand. Then when cured sand back to wood, so as not to hide the grain.
TinBarnTurner
Texas
I do understand how far it is to Lubbock. LOL. When we lived in the Metroplex, our daughter went to and graduated from Texas Tech. I have made that trip many times. But hey, if you are from Texas driving long distances is the norm.
TBT
Bikerdad
Utah Valley
TBT
If you're from anywhere out West other than the Left Coast, driving long distances is the norm.
farmer
NV
wax paper
Hi TBT.
TBT
I keep a roll of wax paper right next to the blue paper towels.......
put the wax paper between the bushing and your pen blank .
Farmer
TinBarnTurner
Texas
Hi TBT.
TBT
Farmer
That's a great idea about the waxed paper between the bushings and the pen blank. A friend suggested putting wax on the bushings where it would touch the pen blank. I tried that and it worked great. The only wax I had laying around was car wax. Hey, it worked.
I will try the waxed paper trick as well.
