Finish for Acrylic Acetate
elody21
For finishing Acrylic or other plastic I start out using a 220 grit to even out the blank from gouge or squew marks. I then use a 600 grit then 800 grit. These two can be as wet sanding if needed. At that point you can use Novus #2 for fine scratches and then Mylands friction polish. But, if you really want to get a great shine get a set of micro mesh! It goes from 1500 all the way to 12000! And what a shine! Just like glass! I only started using micro mesh about a month ago. I cannot believe what I was missing all of this time!
Good Luck!!!
elody21
If you do get micro mesh it goes without saying that you still use the steps above only save the Novus and Mylands until you go through all of the micro mesh stages. Also Micro Mesh is made to use as wet sanding only! If you sand without water it backing will melt!
Fred in NC
LANDIS, NC, USA.
Original post:
http://www.penturners.org/forum/topic.asp?TOPIC_ID=1798&whichpage=1#11652
Micromesh chart site:
http://www.ss-sci.com/micromesh.htm
Please note that most sandpaper we buy has CAMI/USA grit size markings. However, some oriental imported sandpaper has the European markings.
That is why I say that it does not make much sense to sand beyond 400 grit if you are going to use MM.
Tom Stephens
Branchport, NY, USA.
Originally posted by elody21
<br />If you do get micro mesh it goes without saying that you still use the steps above only save the Novus and Mylands until you go through all of the micro mesh stages. Also Micro Mesh is made to use as wet sanding only! If you sand without water it backing will melt!
Micro Mesh is <b>not</b> for wet sanding only. I never use it wet and do not melt the backing. I use both the sponge backed double sided pads and the plain sheets. It takes some expirementing to find the proper speed and the correct amount of pressure to apply. I use it for wood and acrylic both.
Tom
btboone
Roswell, GA, USA.
For acrylic, I use spongeback 8000 and 12000 grit dry by hand and go against the machining marks. From there, it can be nicely polished with a very soft buff and some white rouge.
elody21
What I wrote is what works for me. It does not really matter if they are two different grit systems or if someone wants to use it wet or dry.I was going by the nembers on the back of the micro mesh. I was told by woodturngz that is was to be used wet when use on plastics and that was the original question. If you are turning some plastics like home cut bowling ball or cast acrylic and you are turning them very thin it is possible to over heat the plastic to the point of distortion and using the MM wet helps revent this.
woodpens
Webb, AL, USA.
I agree with "whatever works for you is what you should do." However, I think Woodturningz missed the mark on this one. I wish the photo showed the finish better on this pen, but I used Micromesh dry, and it is glossy as glass. I have never used Micromesh wet, and it works great on acrylic and wood alike.
wayneis
Okemos, Michigan, USA.
If anyone cares to go by the manufactures instructions which is what I believe Woodturnz did then they say to wet sand acrylics and dry sand woods. At least on the sheet that was supplied with my set of Micro Mesh. I do think that if you wet sand it will make MM last longer and you take little risk of over-heating the acrylic or MM. I've been using Micro Mesh for about five years now and swear by it for most all woodworking projects. I also wet sand wood using Danish Oil on my Jewelry boxs and picture frames and the finish is babies butt smooth.
So the bottom line in my opinion is that everyone should just do what floats your boat, if it works for you then do it.
Wayne
woodpens
Webb, AL, USA.
You'll be thrilled with the results of micromesh, especially on acrylic. Just use a light touch and let the micromesh do the work.
Gary
Texas, USA.
I was skeptical of Micro Mesh until I used it. It's a great product, and I'm amazed at how long it lasts.
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
The only thing I can add about micro-mesh is to not let it get hot while you are sanding. Other than that precaution, the stuff is wonderful with loads of uses other than penturning.
Gregory Huey
Fallston, Maryland, USA.
Keep it moving while you are sanding or it will burn. Other than that it is one great product. Just put it in your pants pocket when it is cloged up and wash it. (don't run it through the dryer) just lay it out and let it dry.
PenWorks
Scottsdale, AZ
Forever & ever & ever.....I have been using the same batch I bought for at least a year now. It might be pricey, but is a great VALUE.
Anthony
Tom Stephens
Originally posted by Gregory Huey
<br />Keep it moving while you are sanding or it will burn. Other than that it is one great product. Just put it in your pants pocket when it is cloged up and wash it. (don't run it through the dryer) just lay it out and let it dry.
You have to practice to keep it from burning. You may have to slow down your lathe.
I also learned that you can clean MM quite well while you are working by rubbing on your jeans. I was very surprised.
Tom
jwoodwright
Anchorage, Alaska, USA.
Everyone knows MM was first used to refinish Aircraft Windows. After time they get scratched and worn and all that UV...
MM removes these scratchs, etc. The windows look crystal clear.
They're still scratched, just too fine for the naked eye to see...
Polishs have micro abrasives that leave the finest scratch pattern.
Difference between a fine tip pen and a 1" paintbrush...[8D]
wayneis
Some of the MM is so delicate that the Violin Company where I buy all my MM has a kit for repairing CD's, it includes a small rubber mat to keep the CD from sliding around, a small piece of 12,000 and some of the very fine polishing licquid compound and a small piece of soft flannel cloth. You can do lot's of stuff with MM. By the way, for anyone needing MM the Violin Company has the best price of anyone with no minimum order.
Wayne
