Finishing It ain't a pen till it's FINISHED! |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
I am new to turning pens , and want to try and get the best possible finish on acrylics. Do you sand through 12000 micro mesh at a high or low speed? Heavy pressure or light preasure? Any feedback would be a great help. Thanks guys and gals
#4 (permalink) |
Some new turners don't realise how much material wet and dry sanding can remove even with fine grits so, I support the advice giving above...!
Cheers George
__________________
"Don't give others what you don't like for yourself" Email: nyodine@yahoo.com.au Web-Store: https://www.georges-bits-of-timber.com/ |
#6 (permalink) | |
Member Liaison
Instead of heavy pressure, use lower grits and move up using the next up grit. I have noticed over the years that "heavy pressure" is used when a slight defect is noticed and one (we or I) want to get it out without having to go back down a grit. Take your time and enjoy the journey of pen making. It is the enjoyment of the journey that produces the best pens.
__________________
Hank Lee Experience is what you get when you don't get what you wanted! ![]() |
#7 (permalink) | |
You are going to get a ton of excellent, up to date advice from experts here. You also may try in the search box "Scratch free acrylic Finish". You may find a process that appeals to you. Happy turning and finishing!
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln Peace, Tony Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA |
#10 (permalink) |
I agree. Low speeds. My pen lathe goes down to two hundred something. That's good. I also support clearing off the mess from the previous grit before the next one. I keep separate "baths" of water for each grit (the plastic cream cheese tubs from Panera work great ).
__________________
Ted in Michigan Go Buckeyes! |
Bookmarks |
Tags |
acrylics , finishing , sanding |
Thread Tools | |
Display Modes | |
