Engraving/finishing question - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 07-05-2017, 12:07 PM   #1 (permalink)
Photos: 0
Default Engraving/finishing question
Hi,
I have to get a few pens engraved. I plan to finish thme with CA.
I have never had this done before.
Do i engraved after or before finishing?
I was wondering if the laser would ruin the finish.
Thanks for your help.
Chung is offline   Reply With Quote Top
Old 07-05-2017, 01:51 PM   #2 (permalink)
Robert Taylor's Avatar
Photos: 0
Default
I do a CA finish first, then have it engraved. The laser does not harm the finish.
__________________
Bob in Ohio
"if at first you don't succeed, maybe parachuting isn't the sport for you.".
Robert Taylor is offline   Reply With Quote Top
Old 07-05-2017, 03:00 PM   #3 (permalink)
Photos: 0
Default
Thanks Bob
Advertisement
Old 07-05-2017, 06:35 PM   #4 (permalink)
Woodchipper's Avatar
Photos: 1
Default
Bob, do you put another coat of CA on top of the engraving?
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 07-05-2017, 06:40 PM   #5 (permalink)
Photos: 0
Default
I do not apply anything after the engraving is done.
__________________
Bob in Ohio
Old 07-09-2017, 10:09 PM   #6 (permalink)
Photos: 3
Default Engrave first?
I was thinking about this and wondered if the gloss from CA would reflect some of the light causing a lighter engraved image.
I will sand down and engrave before applying the finish. I figured the ca would fill in the engraving marking for a smoother finish.
Looking for other thoughts on this.
KB8JXO is offline   Reply With Quote Top
Old 07-09-2017, 10:34 PM   #7 (permalink)
stuckinohio's Avatar
Photos: 3
Default
Personally I always CA finish after engraving and color fill is done. This way the color wont chip out or get dirty. The CA finish seals it all and will be perfectly smooth which makes for a nice feel.
I turn the body slightly smaller than the required size before it goes to engraver, then build up above bushing size slightly with CA. Then sand and polish to required diameter.
__________________
Lewis
stuckinohio is offline   Reply With Quote Top
Old 07-10-2017, 07:46 AM   #8 (permalink)
Photos: 2
Default
On wood I usually finish before engraving. I find that the laser will engrave too hot, too deep etc - especially on softer woods, spalted, burls - but with the CA soaked in and finished the wood becomes more consistent and I get a more consistent engraving. I sometimes add CA after engraving to protect filler paint if used but on wood I find it doesn't usually need it.
__________________
Keith Byrd, Mount Wolf, PA 17347
keithbyrd is offline   Reply With Quote Top
Old 07-18-2017, 01:58 PM   #9 (permalink)
Makereality's Avatar
Photos: 0
Default
I finish with shellac or other friction polish first, which I suspect would distort the light ashy lettering if burned with the low end lasers like the 1500mw Neje style laser I use. The 40 and greater watt lasers can produce deeper carving rather then just top burning, so likely not an issue if the laser burns lower than the level of the turned wood. If by repeat engraving with low end laser the name is lower than the surrounding wood, that would be a great balance, but then the friction polish would accumulate in the depression of the name...I'll experiment if no one already knows...
Makereality is offline   Reply With Quote Top
Old 07-18-2017, 03:26 PM   #10 (permalink)
Rick_G's Avatar
Photos: 30
Default
I have the 1W Neje and always finish with CA before engraving. I tried it with and without finishing and found I get a cleaner more precise burn with the finish on. With the higher power settings I get a deep enough burn I can color fill if I want.
__________________
Rick
I support
The Pens for Canadian Peackeepers Project
http://www.undergroundwoodworking.ca
Rick_G is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
ca finish , engraving
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
