EEE for CA Finish - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 06-25-2017, 09:50 PM   #1 (permalink)
Photos: 11
Default EEE for CA Finish
Based on my observations over the past few months, when it comes to CA finishing folks are either in the micromesh camp or the buffing camp. I started with MM and have had results I am happy with, and haven't tried buffing. But I came across this video where I got the tip to use EEE Ultra Shine instead of MM. I decided to give it a try, and must say I am very happy with the results. I applied the CA, then sanded 400 thru 2000, then EEE, then HUT polish. The result is essentially indistinguishable from MM, in less than half the time. I am a little concerned that scratches might start to show once the waxes from the EEE wears off, we'll see. I'll probably continue to use this method on the slims that I give away at work. I just thought I would share this for others that might be looking for a little time saver.
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Old 06-25-2017, 10:13 PM   #2 (permalink)
bobjackson's Avatar
Photos: 0
Default
I use EEE every time.
__________________
bob Jackson
Elyria, Ohio
bobjacksonoriginals.com
bobjackson is offline   Reply With Quote Top
Old 06-25-2017, 10:17 PM   #3 (permalink)
mmayo's Avatar
Photos: 0
Default EEE
+1 to using EEE and Beale buffs
__________________
Mark Mayo
Kites rise highest against the wind, not with it.
Winston Churchill
mmayo is offline   Reply With Quote Top
Advertisement
Old 06-26-2017, 08:05 AM   #4 (permalink)
terry q's Avatar
Photos: 0
Default
I use Novus heavy & fine scratch remover. It gives he appearance of a deeper finish. Plus it's a lot smoother.
terry q is offline   Reply With Quote Top
Old 06-26-2017, 09:20 AM   #5 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
The problem with EEE is that it wears off in a few days of regular pen usage. For me, it is - "what is the purpose of a shine that will wear off in a few days?" I remember the first pen in which I used EEE over light coatings of CA, and then the embarrassment of seeing the EEE wear off after I gave it to a friend. I stopped using EEE after that. EEE is good for display.
If a pen were on display and barely touched, it will work. The same for furniture polished wood - use it on occasion and wax it every week. Pens are different. I personally prefer a sheen on waxed wood rather than glossy shine that will rub off because the rubbed off spots show through in the long run.
As to MM and other polishes - here is a chart of comparison grits:
http://content.penturners.org/librar...sive_chart.pdf
I do have some sandpaper (3M) with .5 micron that is finer than 12000 MM. Once that grit is arrived at on a pen, polish and buffing add little else. But there are differences that show up from some people - and that would be "technique" differences, not polish or SP or wax.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 06-26-2017, 10:56 AM   #6 (permalink)
Photos: 59
Default
I have never used EEE on a pen. I did use something similar called Tripoli polish when doing sterling silver jewelry to remove scratches. This came in a bar and was applied using a buffing wheel.
I do use MM from 1500 to 12000 after using 500 grit and 1000 grit wet or dry. I use a spray bottle with two or three drops of dish soap in the water to help eliminate surface tension issues with the water. I then use a plastic polish as it appears to put the final shine onto the CA or acrylic finish.
eharri446 is offline   Reply With Quote Top
Old 06-26-2017, 12:54 PM   #7 (permalink)
KenV's Avatar
Photos: 0
Default
Sam, there are at least 40 more camps out there in the trees and brush. And there may be a lot more.
There is a general philosophical divide though, with two polar points. Those who finish to "good-nuf" and those seeking the skills to finish to the quality of $1000 + pens.
Each has to decide where they head. I have had a couple of top end pens in hand and am inching my skills that direction.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 06-26-2017, 12:54 PM   #8 (permalink)
Photos: 4
Default
The EEE is basically the same as Tripoli, but more wax than abrasive. That's where the name was derived from... Triple E.
The fastest way to achieve a glass sheen, and best result, at least for me, is to sand to 220 grit. Where one starts is dependent on the surface after turning, or in some cases, cutting. After using the 220 grit, I use Tripoli on two different types of wheels (concentric and loose), and then to the white rouge on a loose or string buff.
After practice and a technique a person finds for themselves, the finish is flawless to the naked eye. This is how average people judge a finish, just by looking at it and feeling it, in my experience. And the whole procedure only takes a couple of minutes for a double barrel pen.
There is a difference in buffing and polishing.
I find the MM a waste of time and if using compounds, it's a step backward.
I'm sure you find this worth the price that was paid.
__________________
-John-
Terredax is offline   Reply With Quote Top
Old 06-26-2017, 02:57 PM   #9 (permalink)
magpens's Avatar
Photos: 49
Default
OK, I'll bite ! . What's the diff between buffing and polishing ?
Yeah, I know there is a diff but just want to hear it from someone; the answer might be educational to more than me.
__________________
Mal
magpens is offline   Reply With Quote Top
Old 06-26-2017, 03:52 PM   #10 (permalink)
Photos: 11
Default
Quote:
Thanks John. I'm going to add a set of buffing wheels to my wish list. It would have been nice if more of the "beginner" penturning videos out there would go over some of these techniques (TBC, drilling on the lathe, etc). I guess it is all part of learning, but it sure would have saved me a bunch of time and money to go straight to the best techniques.
__________________
--Sam
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
