CREID
I just drilled and glued an Ebony blank. While I was doing that, I thought to myself, Ebony is oily. My plan then is to after turning, wipe it down with acetone and then apply CA. I have never used Ebony before, so I am reaching out here to see if this should work. I have some shellac based finish handy, but as you know they don't hold up well under handling. In your opinion, will I have problems down the road with oil migrating to the surface and lifting the CA?
Thanx
Curt
Thanx
Curt
