dyeing antler
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
Yes, I have dyed deer antler with transtint dye/alcohol. It worked wonderfully! I use blue and it gave a nice light blue hue that did not look fake. I also stabilized some Axis antler from a deer that I killed while still in velvet. Once the velvet came off, the antlers were very porous so I cast it in Alumilite and got color and added density. Will try to post a pic one of these days.
jskeen
Crosby, Texas, USA.
The classic method of rebrowning antler that has weathered too grey is to soak in a saturated solution of potassium permangenate. Depending on how long you let it set, this will turn the exposed sections anywhere from light tan to dark chocolate. Dying the antler to a medium tan and then sanding the high spots will usually turn old grey antler back to almost new looking.
Potassium permangenate crystals can be purchased at plumbing supply houses and most sears stores in the plumbing section. It is used to back flush the filter beds of water softeners. simply mix 2 or 3 tablespoons in a jar with a lid and shake for a moment. Use gloves and wear old clothes, it stains hands and fabrics bright purple. DAMHIKT
