cleaning delron bushings
sgimbel
Round Rock, Texas
Can I clean delron bushing by soaking them in acetone without destroying them? If not how do I clean CA buildup off them? Thanks in advance.
johnnycnc
columbus, IN, USA.
You sure can. I have tested it and there are no issues.
After you get them clean, I recommend mounting them with a blank tube
so you can access them and using 1000 or 1500 grit wet-dry auto paper and perhaps ren-wax as a lubricant to sand with. buff off lightly when done .
this is a big help in making them a bit more stick resistant, as it polishes the surface a bit and the wax helps some too.
John
CharlesH
Canada, Quebec, Laval
I usually just cut the glue excess with a skew and when the bushings are worn off I just but new ones from my friend Johnny! ;-)
C
Sent from my Samsung Galaxy S2.
