HawksFeather
I am no way close to the ability of MANY of you when it comes to CA finishing. I had three pens that I worked on today and two are pretty good for me and the third one is almost pretty good. There is a spot in the Rosewood Burl that just will not take the CA. I have gone over it many times and the CA will just not "stay" in that spot. I have tried wiping with DNA and then applying CA, acetone and then CA, sanding and then CA, lacquer thinner and then CA, CA accelerator and then CA and each and every time it will run off of this spot like it is going on over wax. The spot is between 1/16 to 1/8 inch wide and about 3/16 inches long. I can cover it with the clip and it won't show, but it is driving me nuts.
Any suggestions?
Thanks,
Jerry
Any suggestions?
Thanks,
Jerry
