CA over Sanding Sealer or shellac? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 10-29-2016, 10:18 AM   #1 (permalink)
Warren White's Avatar
Photos: 0
Default CA over Sanding Sealer or shellac?
Can I apply CA over Cellulose Sanding Sealer? What about over shellac?
(I know I can.... but should I?)
I am turning a pen out of cherry and I would like to enhance the color a bit.
Thank you!
Warren
Warren White is offline   Reply With Quote Top
Old 10-29-2016, 10:44 AM   #2 (permalink)
Dan Masshardt's Avatar
Photos: 0
Default
I'm not sure that either of those will change the color much unless the shellac is tinted. Sanding sealer does nothing to enhance color in my experience.
I think cherry looks great with ca.
If you do use shellac, dewaxed is best.
You might want to try a wipe with blo then ca.
Sent from my iPhone using Tapatalk
Dan Masshardt is offline   Reply With Quote Top
Old 10-29-2016, 12:48 PM   #3 (permalink)
Photos: 0
Default You are right, Dan
I just tried a sample and it didn't make any change to the color. I was wondering how it might affect the CA.
Whatever effect it might have, it really isn't worth it.
I agree about the Cherry. It is one of my favorite woods. I just wanted to 'boost' it a bit.
Thanks,
Warren
Advertisement
Old 10-29-2016, 01:40 PM   #4 (permalink)
Photos: 7
Default
I use a combination of Minwax Stain'n'Seal and CA for my usual finish .... but the stain is a "natural" color, sort of a light amber. It makes the wood appear to be wet, in appearance, and helps deepen the colors and highlights. It also happens to contain some boiled linseed oil, so it also has the same effects as the BLO+CA combination, where the CA cures a little faster.
If the "natural" look isn't quite dark enough for you, you could try enhancing the blank just before application by applying heat to darken it or possibly a dye or stain to darken the blank? In addition to those options, Minwax does, of course, carry actual stain colors in that exact same product line, if you want to try them out ... I got a pint can of it for around 7 dollars, I think.
__________________
Click Here to go to Pen Turner's Anonymous Meeting
Attendance is not mandatory, unless you're addicted to turning pens.
Skie_M is offline   Reply With Quote Top
Old 10-29-2016, 01:56 PM   #5 (permalink)
Photos: 0
Default Sanding sealer
Thank you!
Warren
Sanding sealer is shellac except it has more denatured alcohol in it .
Both are Lac bug $hit
farmer is offline   Reply With Quote Top
Old 10-29-2016, 07:47 PM   #6 (permalink)
Photos: 0
Default
"Both are lac bug . . ." Is that a problem?
donstephan is offline   Reply With Quote Top
Old 10-29-2016, 08:11 PM   #7 (permalink)
Photos: 7
Default
The products that you know as "shellac" and "sanding sealer" are based from the same source .... the dung from the female lac bug....
__________________
Old 10-29-2016, 09:11 PM   #8 (permalink)
Photos: 0
Default
Shellac is often used as a sanding sealer. However, cellulose sanding sealer is an entirely different animal. It is basically nitrocellulose lacquer that has had stearates added to it to give it a fast build and to make it easy to sand off.
There is a good article on sealers by Michael Dresdner here:
When to Use Sanding Sealer / Rockler How-to
And another by Bob Flexner here:
Shellac as a sealer? It
FWIW
Bill
bmachin is offline   Reply With Quote Top
Old 10-29-2016, 09:32 PM   #9 (permalink)
Photos: 0
Default
Not sure if this is what the OP meant but it is the same question I have. If you use shellac/sanding sealer, BLO or WOP, and then apply CA, will the CA adhere and will it stay on over the long term? I've heard some say that they apply CA over BLO without issue and some say that when they do that, the CA has a tendency to separate. So, does anyone have $0.02 to throw in? What is your experience?
TongueTied is offline   Reply With Quote Top
Old 10-29-2016, 10:06 PM   #10 (permalink)
MrKugelschreiber's Avatar
Photos: 0
Default
I'm not sure I see a reason for a sanding sealer if your gonna use CA. CA will fill the pours.
MrKugelschreiber is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
