Haynie
I am working on a pen and everything has gone wrong. You name it it has happened. I have had to turn the CA off this pen three times so far. Those three times were my fault. The fourth time was supposed to be a charm and it was. When I finished the initial application of the CA it was good to go. Considering the last time I CAed a pen it turned white because, I assume, water got under the finish at the end or it was not cured enough. I let the dried tubes sit on the lathe bed for a couple days just to be sure. In that time it got cold. Our high today was in the 30s and it rained/snowed too. When I went to sand and finish the tubes I noticed cracks These were not there 3 days ago. The cracks follow the CA swirl pattern I always get when I build the CA up. This has not happened before. I sanded with 400 then hit the tube with rubbing compound to see if the cracks were just hanging out. They are all the way down to the wood. I am seriously scratching my head on this one.
My camera will not focus close enough to get a pic. Could these be freeze cracks? And if so how did it happen? They are only where the high points are/were in the finish.
Stats
Wood-Amboyna burl
2 coats of Stickfast thin CA then 5-6 coats of medium
Stickfast accelerator between coats of medium.
Help
Stats
Wood-Amboyna burl
Help
