CA finishing problem ??? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 03-03-2014, 10:02 AM   #1 (permalink)
Photos: 0
Default CA finishing problem ???
Hi,
I have just recently started to make pens, and facing this CA finishing problem.
After watching hundreds of clips on YouTube about CA finish, since they all make it appear to be an easy process, I decided to give it a try.
The problem I am having is as soon as I apply the CA accelerator (not the spray can but the pump), the pen instantly turn cloudy/foggy white. With sanding, I can get rid of this white aspect, but I wonder what I am doing wrong.
Without the CA accelerator (Satellite City to not name it), I get good results, but I need to wait 5 minutes between each coat, which makes it a long process for a single pen
I tried it on different type of wood, tried thin and medium CA, and running at low speed (500rpm) but no avail yet.
Any suggestions?
pierre2342 is offline   Reply With Quote Top
Old 03-03-2014, 10:30 AM   #2 (permalink)
Pitoon's Avatar
Photos: 0
Default
Quote:
Originally Posted by pierre2342 View Post
Hi,
Any suggestions?
yes, the foggyness can occur. try spraying lighter and a bit further away.
if you use a thin or medium viscosity glue it will dry up within 30secs depending on how thick of a coat you are putting on. more thinner coats are better than fewer thicker coats. also when you put on thicker coats it tends to always sag/drip once you turn off the lathe. then you have a lot of sanding/shaving to do to get it back round again.
just my two cents...
Pitoon
__________________
....always thinking 3 projects ahead.
www.UnitedHerps.com . My personal Facebook page . United Herps Facebook Page
2014 - 5th place Advanced Beautiful Pen contest / 6th place Antler, Bone and Horn Pen Contest
Pitoon is offline   Reply With Quote Top
Old 03-03-2014, 10:32 AM   #3 (permalink)
Photos: 0
Default
Use aerosole accelerator with short burst from 12" away while the lathe is running. The pump applies too much accelerator in small spots.
__________________
www.etsy.com/shop/MyPenPlace
raar25 is offline   Reply With Quote Top
Advertisement
Old 03-05-2014, 03:26 AM   #4 (permalink)
Photos: 0
Default
Step back some. I had the same problem but with the spray (never used the pump). I took a full step backwards and vuala.
hagemierj is offline   Reply With Quote Top
Old 03-05-2014, 07:14 AM   #5 (permalink)
johncrane's Avatar
Photos: 190
Default
Try putting the accelerator on using paper towel with lathe off,you can turning lathe by hand, you don't need much accelerator one squirt on the paper towel then rub it length ways along the blank.
__________________
SUCH IS LIFE. Down Under.
johncrane is offline   Reply With Quote Top
Old 03-05-2014, 07:48 PM   #6 (permalink)
Wood Butcher's Avatar
Photos: 3
Default
Very lightly spray the accelerator at least 18" from the pen, across the room will work too. As long as it's in the neighborhood it will work.
WB
__________________
Whenever I fill out form , in the part that says, 'In case of emergency, notify: I always put 'DOCTOR.
Wood Butcher is offline   Reply With Quote Top
Old 03-05-2014, 07:59 PM   #7 (permalink)
Photos: 72
Default
Use thick or gap fillng CA, it drys slower, gives you a longer working time, and will not cloud up when accellerator is applied if you wait 5-10 seconds before applying. Thin or medium CA will cloud up and fume if accellerater is applied too quickly or you are tring to fill in a hole or gap and it's puddled. It's worked for me for many years. Jim S
plantman is offline   Reply With Quote Top
Old 03-05-2014, 08:27 PM   #8 (permalink)
Banned
Photos: 0
Default
Many times, the pump accelerator is DNA or isopropyl alcohol, it will fog CA in half a second!! Try the aerosol CA...short burst...I like 18-24" away, but JMHO.
Jim Burr is offline   Reply With Quote Top
Old 03-05-2014, 10:19 PM   #9 (permalink)
Quality Pen's Avatar
Photos: 4
Default
I am a newbie as well. I have found a similar issue using the pump spray accelerator.
First of all, I notice that it does not seem to be an evenly distributed projection of accelerator. But also, I find that some areas can receive too much accelerator.
I actually decided next I would try the aerosol because it seems to be both a finer spray and more even throughout.
I was wondering, what is in the aerosol accelerators? Same as pump? Mentioned above, is DNA denatured alcohol?
__________________
"And finally, it CAN BE DONE. It HAS been done by more than one member here." -PenMan1
Quality Pen is offline   Reply With Quote Top
Old 03-05-2014, 11:24 PM   #10 (permalink)
thebillofwrites's Avatar
Photos: 2
Default
When I use accelerator, I apply it with an inexpensive air brush.
It allows you to apply just a very fine mist.
I have it hooked up to a spare tire for air pressure. Nice and quiet. Just have to pump up the tire every now and then.
Bill
thebillofwrites is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
finish , problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
