CA finish question - Will it apply very well when cold? - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 12-05-2016, 02:37 PM   #11 (permalink)
PenPal's Avatar
Photos: 1
Default
Quote:
Originally Posted by TonyL View Post
I'm sure Chuck is right. To be as sure as possible given your brand, you can always apply a coat to an unturned blank and then see what a shot a accelerator will do.
My problem is finding completely compatible glue accelerator. It seems in this country the mystical accelerator assumes rarity and high costs. Seeing white reactions destroys the moment.
Peter.
__________________
Penpal Nil Desperandum
PenPal is offline   Reply With Quote Top
Old 12-05-2016, 03:17 PM   #12 (permalink)
EBorraga's Avatar
Photos: 61
Default
Forget the CA, what about yourself!! I hate being out in the cold. Especially when you can't feel your fingers
__________________
Regrets in death meant you've lived life wrong.
Check out my Facebook page at https://www.facebook.com/EBWoodworx/
EBorraga is offline   Reply With Quote Top
Old 12-05-2016, 06:03 PM   #13 (permalink)
Dalecamino's Avatar
Photos: 219
Default
Peter.
Peter, I've used Zip Kicker with a few different brands of CA. It appears to be compatible with many brands.
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Advertisement
Old 12-05-2016, 06:47 PM   #14 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Accelerator does what it is supposed to do, but it usually creates heat in the process. Heat and cold in even moderate humid/moisture situations will draw moisture into the mix. Cloudiness, white specs occur much more so in cooler and colder situations for me. I realize that some of you have experience in avoiding the white spots and cloudiness underneath. If you could elaborate on how to prevent that in cold weather, it might be helpful.
Now if you are in ARIDzona or the Sahara, I could understand.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 12-18-2016, 12:35 AM   #15 (permalink)
Photos: 4
Default
I have a kerosene heater for the garage that warms it up nicely, but it dumps tons of moisture into the air. I also turn and finish without the heater when it's about 50 degrees in there. I use the original and their new Flex CA from Mercury Adhesives and it does great in all seasons.
__________________
Robert Kulp
robert@TennesseePenSupply.com
Robert Kulp Creations
robertkulp is offline   Reply With Quote Top
Old 12-18-2016, 03:31 PM   #16 (permalink)
magpens's Avatar
Photos: 49
Default
As I understand, CA curing is a chemical process. Most chemical processes proceed more slowly at lower temperatures. Even though you apply accelerator, the chemical reaction involved in CA curing will be slower. Therefore you have to allow longer time between applications of CA/accelerator, and you have to allow longer time after your last application for the overall curing process to occur.
A lower air temperatures, the humidity is usually lower, so I would think that adverse humidity effects would be lessened during CA application in cold weather.
I would think that you should allow extra time before bringing your CA-coated blank indoors, because indoor temperature air will have higher humidity and could affect the coating.
I keep those considerations in mind when working with CA and have had no problems.
When I was a novice with CA, I used to have the whitening problems often mentioned.
I can't explain the reason, but in the last 4 or so years of working with CA finishing I have had no whitening problems. It seems to me to be a matter of technique but I don't know what improvements I have made.
__________________
Mal
magpens is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
