Quote:
Originally Posted by PaulSF
When you turn between centers, during the turning phase do you still use bushings to get to the proper circumferences, or do you use calipers?
I use calipers and never trust the bushings. Bushings are usually sanded down or touched with the chisel. For a long time, many people considered the bushings as a disposable item because it was constantly being worn down. And as it wore down, then sizing became a problem. So, if calipers are used, you never have to depend on the bushings for sizing.
One reason for calipers is this: the nib end, the center band and the clip end - all vary .001 or even .002 or more from the bushings. I always turn my blanks to the sizing on the CB, nib or clip end. Never to the bushing. Actually I turn it down .003 or .004 below and build that back up with CA for a more precision fit.
