woodscavenger
I have just started using the CA-BLO finish. I have had mixed results but mainly good ones. Here are some things I have learned as well as some basic questions.
1. Expensive paper towels may be worse for the finish. I was initially using cheapo towels but then I splurged and bought some "supe absorbent" Viva towels. Althought the BLO was less likely to seep through, the thicker towel seemed to catch on the CA and a couple of times pulled it out of my hands and wrapped itself up. The cloth-like appearance seem to be a hinderance. I went back to the cheapo towels and no more shedding problems.
2. I apply a thin line across my towel then apply it to the underside of the spinning blank and rub back and forth vigorously until a shine reappears. I seemed to have a tough time getting even results when applying the glue to the wood/towel junction. It also keeps me from getting closer to the fumes.
3. Applying friction finish needs to be done carefully or not at all. I have had two sets develop a circumferential "blister" under the CA. I now think it is because I was pressing too hard to generate heat for the friction polish and it somehow blistered. Had to sand down and restart.
