First time using CA BLO on a blackwood pen.
Applied "as per normal", but it doesn't seem to want to take "as per normal" (normal being the Fairfield technique).
The glue goes on fine, the oil goes on fine, but the curing process leaves the surface kinda pitted, kinda speckled....bumpy???!!!
When I sand away some of the excess, I get a fog that creeps into the the visible parts of the end of the wood, creeping in no more than 1/4", then retracting a bit.
Now, the only thing different is I may have put a bit much Ren. wax on the ends of the bushings (to prevent the glue from adhering to the bushing) and it may have creeped onto the pen.
I am concerned I have contaminated the pen permenantly because I have soaked the bushings in acetone (should I use paint thinner?) and sanded the ends of the blank, remounted the pen to the mandrel and had the same problem.
What to do??
BTW: how much sanding does it take to sand through 1 coat of CA BLO? I'm on the 4th coating...is there enough, do you think, to keep doing this bothced method, sand it smooth again, apply again etc, and then do MM 6000-12000 and finish with HUT and Ren wax again?
Hoping to salvage this one, as I have just started the cap, and it's for an Emperor. Not that I care if I waste the blank and a tube, I just don't want to assemble it and have time pay it's duty on it.
Thanks.
What to do??
Thanks.
