building a buffing center
LOIBLB
kennedale, Texas
This pen with the black back ground proved to be difficult to polish perfectly with no sign of marks. I need to build a buffing center if I keep doing these.
Where did you buy or build yours?
mecompco
Fairfield, Maine
I'm not sure a buffer will take out those scratches. Are you using MM pads and sanding laterally as well as radially? I like my barrels to be scratch free before taking them to the buffer. I use PSI's three wheel system, which I understand is a rip-off of Beal's system. I keep it permanently mounted on my HF lathe.
Regards,
Michael
JimB
West Henrietta, NY, USA.
What is your current sanding and polishing process? That may be where your problem is.
A buffing system can be anything from a do it yourself system using HF buffs to buying a complete system from places like Woodcraft, Rockler, CSUSA, PSI as well as many other places. It really depends on what you want and what your budget is.
KCW
Lincoln, NE
I agree with Michael on this. When I started, I thought I could buff out larger scratches also, and would spend far too long at the buffer, trying to get a decent outcome. I finally decided to get my sanding process down, and it saved me so much time and effort. But to answer your question, you can buy a buffing system almost anywhere pen parts are sold, or you can make one yourself, like Tony L did http://www.penturners.org/forum/f28/my-alternative-mm-wet-sanding-135154/
Edit- Guess I was a little slow at typing this out.
lhowell
Apex, NC
I don't have a buffing system but ditto on the sanding laterally. I start at usually 180 or 240 and go up to 12,000 with the Micro Mesh pads. My lathe is capable of running in reverse so I usually sand at low rpm (around 500) in "reverse" stopping the lathe after each grit and sanding the blank(s) laterally while manually turning the blank. Then just to be on the safe side, I take my work light and use a "raking light" in multiple directions to make sure I don't see any visible scratches before moving up to the next grit. Once I reach 12,000 grit I will either use Novus or Meguiar's Plast-X.
Black is extremely hard to get perfectly scratch-free but with patience you can do it!
Skie_M
Lawton, Ok
Sanding laterally between the grits is the major key you are missing for your success ....
Finishing the process with Plast-X or another polishing compound would do the rest.
Also, using Turtle Wax or another wax compound at the end helps, I hear, with preventing fingerprints from showing up quite so much... :)
