keithncsu
I've done several searches on this and read tons of threads. I think my question/issue/confusion/whatever you want to call it may just be from inexperience. I think the threads I've read have a level of understanding/common knowledge that I'm either missing, or way overthinking. Either way, here goes.
I recently purchased the 4" individual buffing wheels from CSUSA to give buffing a try. Most of the threads I've read seem to talk about buffing acrylics, which makes sense and is straightforward.
I'm struggling to understand the process on wood pen blanks though. I tried a slimline tonight with some cheap wood just in case I messed up. Sanded the blanks to 800 grit and then went straight to Tripoli. Then hit the white diamond. The finish wasn't super shiny, but I expected that.
So is that the normal process or are you guys putting some sort of finish BEFORE buffing?
Also, am I to assume buffing unfinished wood will essentially have the same durability as a friction polish?
Again, if these are rookie questions, I apologize. Thanks for any input!
