Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
Finishing It ain't a pen till it's FINISHED!
Reply
Old 04-21-2011, 10:58 PM   #1 (permalink)
Photos: 0
Default BLO & CA
I have made about 10 pens using the alternate BLO, CA (medium) approach - about 5 layers on a medium speed. I move quickly so not to have any buildup. I don't have any cloudiness and the pen has a nice shine to it. I also finish it with either Rennaissance wax. The problem (or concern) is that the pen has shine but doesn't really seem to have any depth to the finish. Also, after a day of handling the pen it seems to loose some of its shine. Looks more like Semi-gloss/satin than gloss or high-gloss. Am I doing something wrong?
mdwilliams999 is offline   Reply With Quote Top
Old 04-21-2011, 11:04 PM   #2 (permalink)
thewishman's Avatar
Photos: 0
Default
You may be sanding through the CA.
__________________
Chris
Non Impedite Raditioni Cogitationis.
(Unencumbered by the thought process.)
Tom and Ray Magliozzi
thewishman is offline   Reply With Quote Top
Old 04-21-2011, 11:05 PM   #3 (permalink)
KenV's Avatar
Photos: 0
Default
Depth of the light reflection (chatoyant) starts with a good surface on the wood and builds with the finish.
You can over work/polish the surface of the wood and loose depth. 600 grit to 1000 grit abrasives seem to be about optimal. Back lighting to assure the surface is smooth helps.
I often use a "scratch remover" too.
Note that you can develop the premium finishes with lacquer, Enduro etc also --
__________________
Ken Vaughan
Old Foopus Apprentice Machinist - Back in Alaska
KenV is offline   Reply With Quote Top
Old 04-22-2011, 03:43 PM   #4 (permalink)
Photos: 0
Default
Ken, do you feel that using the micro-mesh is overkill. Currently I use MM in order to 12,000 and then apply the BLO and CA. Maybe I should try a pen stopping at 600 grit and then apply BLO and CA to compare the differences.
Chris, I'm not sanding between each application of BLO and CA.
Old 04-22-2011, 03:55 PM   #5 (permalink)
G1Pens's Avatar
Photos: 145
Default
I sand to 600. Apply CA/BLO THEN...if I want high gloss with lots of depth, I MM to 12000. If I want it to look more natural I leave it as is or only partially go through the MM.
__________________
Gary V Kohl
G1 Pens
Winner 2011 Beginner's Most Beautiful Pen - Birthday Bash
"nisi dominus frustra"
G1Pens is offline   Reply With Quote Top
Old 04-22-2011, 03:59 PM   #6 (permalink)
Craftdiggity's Avatar
Photos: 0
Default
Even if you build up several layers of CA, it is not hard to sand through it. What I do is apply 6-10 coats of CA, then sand from 400 up to 1200. I then apply 3-6 more coats and lightly sand again up to 1200 just smoothing the bumps. After that I buff with the Beall system and...viola! This ought to give you a nice finish with some depth.
__________________
Chris Merlino
If at first you don't succeed...
Deny you ever tried.
www.woodntreasures.com
Craftdiggity is offline   Reply With Quote Top
Old 04-22-2011, 04:03 PM   #7 (permalink)
Whaler's Avatar
Photos: 6
Default
I sand the blank to 600, apply 6 to 8 coats of med CA/BLO and go straight to the Beale wheels. I never sand after the finish is applied.
Whaler is offline   Reply With Quote Top
Old 04-23-2011, 07:56 AM   #8 (permalink)
Rangertrek's Avatar
Photos: 33
Default
So many methods and finishing techniques! Nice to see the options used by our many members to get a nice finish.
I sand to 600 grit, apply 2-4 coats of thin CA, then 4-6 coats of med. CA, maybe a scratch cover and then plastic polish. No sanding after the ca is applied.
__________________
"Courage is being scared to death... and saddling up anyway." [John Wayne]
2nd Place - 2011 Edible Pen Contest
Ranger (2001 -2011) Our Beloved Shelty
John Carlisle
Rangertrek is offline   Reply With Quote Top
Old 04-26-2011, 04:21 PM   #9 (permalink)
rsulli16's Avatar
Photos: 0
Default
ca and blo have gone good for me the last few times, soo, here's another 2 cents worth. i sand to 600, wet with blo. then a drop of blo on the towel, a drop of med. ca on the oil, rub fast and lightly. 10 coats. then "eee" and plastic polish. (fingers crossed) i hope i got it this time, worked real well. i gave up sanding ca, it dulls it never takes it evenly, or it sands thru in places.
hope this helps
sulli
rsulli16 is offline   Reply With Quote Top
Old 04-26-2011, 04:27 PM   #10 (permalink)
babyblues's Avatar
Photos: 11
Default
It may be that the surface of the CA isn't glassy smooth and the shine you're seeing is from the BLO, which would wear off quickly after handling.
__________________
I could be chasing an untamed ornithoid without cause.
babyblues is offline   Reply With Quote Top
Reply
Bookmarks
Tags
blo , ca
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
