Best paper towel for CA finish - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 04-19-2016, 09:02 AM   #1 (permalink)
Photos: 0
Default Best paper towel for CA finish
Hi Guys
Can anyone tell me the best sort of paper towel to use for a CA finish, I think I have used every make of white paper towel and keep getting the little flects of white in the CA, I have read here some where that blue workshop towel is the best, I have seen SCOT BLUE WORK SHOP TOWEL sold in halfords and notice its make in USA, any one know if this will be any good.
Thanks guys any help will be most welcome.
Tomovacs
tomovacs is offline   Reply With Quote Top
Old 04-19-2016, 09:09 AM   #2 (permalink)
jttheclockman's Avatar
Photos: 104
Default
CA finish with a craft foam applicator
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 04-19-2016, 09:41 AM   #3 (permalink)
Photos: 0
Default
I use polyethylene gloves and polyethylene batting. CA does not react at all to polyethylene. That is what they use for CA bottles.
I cut a small piece of the batting and use it to apply the CA. See http://youtu.be/j6I6lQM1yls for a description of using the batting.
__________________
Firgenholt Turnery
jrecord is offline   Reply With Quote Top
Advertisement
Old 04-19-2016, 10:00 AM   #4 (permalink)
Photos: 4
Default
I get the Scott Box of Rags from Sam's Club. I cut them into strips and fold them over to make a pad for application. It works very well for me.
__________________
Robert Kulp
robert@TennesseePenSupply.com
Robert Kulp Creations
robertkulp is offline   Reply With Quote Top
Old 04-19-2016, 10:03 AM   #5 (permalink)
Photos: 0
Default
I use the Scott's Shop Towels. And they work great!!
__________________
Knowledge is knowing a tomato is a fruit, experience is knowing not to use it in a fruit salad.
Drewboy22 is offline   Reply With Quote Top
Old 04-19-2016, 10:23 AM   #6 (permalink)
Photos: 0
Default
I use the craft foam, it seems to leave fewer ridges for me.
Arbetlam is offline   Reply With Quote Top
Old 04-19-2016, 10:58 AM   #7 (permalink)
Photos: 0
Default
I recently tried the 20 coats of thin CA method as used by David from Timberbits in his YouTube video, with a fresh small piece of towelling per coat. Actually it was the two ends of 10 pieces for 20 fresh ends but close enough. This was with a light spray of activator between coats btw. I used a roll of blue towelling that I bought somewhere here in the UK, probably either Aldi or B&M, and the only problem I had was on one coat where instead of a single rub in each direction I tried two or three and the paper stuck, and so had to sand back down to virtually bare wood. It was only either the third or fourth coat I'd ever applied like this so part of the learning curve. I started again and did the whole 20 coats without mishap, left the CA to sure overnight and then wet sanded with MM to a flawless glass like finish.
Tony Wells, in Leeds.
PS, I used the thin watery CA from PoundWorld, three small 10gm plastic bottles on a card for 1, and as I said above, a flawless finish. I suspect that being so thin helped as it did spread very easily and thus had less chance to grab the paper.
TonyW is offline   Reply With Quote Top
Old 04-19-2016, 11:09 AM   #8 (permalink)
Photos: 0
Default PPS
PPS, I remember the blue towelling only being 1 for a jumbo roll, though it is quite thin. I therefore probably bought it from either B&M or one of the Pound shops, maybe PoundLand. It is quite smooth with less fuzz than supermarket kitchen towelling.
Old 04-19-2016, 11:16 AM   #9 (permalink)
Dalecamino's Avatar
Photos: 222
Default
The BACK side of a Bounty Select-a-Size folded three times, gives you about a 1" wide padded strip. You can get 6 applications with each side.
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Old 04-19-2016, 02:58 PM   #10 (permalink)
Photos: 0
Default Paper towel
My ( theory ) or thought is that white paper towels ( help ) activate the CA faster.
I use the Blue Scott paper towels...
farmer is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
