Beall and Acrylics
JosephDurham
Can you use the Beall buffing system on an acrylic? I guess I should also say that the buffiing pads on the buffing system are new.
Thank you,
Joseph
JosephDurham
Thank you very much Rick. Perhaps you can tell me how you do it? What polish do you use? Which wheel so you use?
I normally use the acrylic high polish for plastics by Crystal Hut for my acrylic pens.
JOSEPH
kronewi
Marion Station, MD
I recently watched a video by Barry Gross. He used the buffing system using Tripoli and White Diamond. Haven't tried it personally.
Kevin
jjjaworski
Las Cruces, NM
For what it's worth............... I have had good results using ZAM and Fabulustre polishing compounds on Acrylics after the wet sanding process.
beck3906
Belton, TX 76513
I actually took one wheel out and allowed extra space between the other 2 wheels. Read the instructions and be sure to use the wheels for the brown and white sticks, as I will call them. (Easier to keep up with.) I don't use the wheel for wax and the wax stick.
Wet sand your pen blank on the lathe to about 400 grit. Remove the blanks from the lathe and then use the Beall system. I hand hold the blanks but you can have the blank ripped from your hands very easily. Practice your style with blanks you don't really care about.You can nruin high-dollar blanks when they go flying across the room.
Use the brown stick (tripoli) wheel first. I make 90 degree passes across the blank. Move to the white stick wheel. The white stick is the diamond polish and will really bring out the shine.
One thing to learn is that the wheels throw off a LOT of strings when first used. Use a mask. Also, you have to "charge" the wheels by getting the wheels full of their appropriate color stick.
If done correctly, you don't need a finish coat.
JosephDurham
Thanks so much everyone!
I just ordered the Beall system for all of my wood pens and products; I also ordered the acrylic pen buffing system found at Pen State Ind. for all of my acrylics. I cannot wait to get them in the mail.
How often do you replace your buffing wheels?
Thank you,
Joseph
srf1114
Mt Pleasant Mi
How far are you wet sanding before Buffing? someone mentioned wet sanding to 400, but that seems low to me.
What "girt" is buffing compared to Micromesh? It seems to me that buffing after Micrmesh to 12000 reduces the finish I received with just the Micromesh?
Kretzky
BC Canada
What "grit" is buffing compared to Micromesh? It seems to me that buffing after Micrmesh to 12000 reduces the finish I received with just the Micromesh?
Have a look at this
http://www.fingerlakeswoodturners.com/downloads/Sand%20Paper%20Grit%20Comparison.pdf
There is also one in the library I believe.
You do indeed have to be careful that you're not going "back" one or two steps.
Joseph replace wheels when they wear out which will be l-o-n-g time from now. Have fun & hope that helps
also have a look here:
http://www.caswellplating.com/buffman.htm
David
beck3906
Belton, TX 76513
I look at saving time and trouble. Buffing or me replaces he need to MM.
JosephDurham
So, here is a question than, and since I am new to buffing I apologize for my ignorance. I have been turning for over ten ears and never used a buffer system.
-what is the purpose of micromeshing if your only sanding to around 600 grit
- if one is capable of getting a high gloss shine by sanding,why use the buffing system
Thanks,
Joseph
Kretzky
BC Canada
Thanks,
Joseph
Hi Joseph, basically micro mesh is very, very fine sandpaper, I usually go thro the grits as necessary to 600 then change to MM. & go thro the grades as listed in the previous post. Currently I don't buff. If you do be careful that you're not going backwards. (ie the buffing compound is coarser than the last grade of MM). There are a number of charts on the internet that give comparisons between paper grits, MM & buffing compounds.
Hope that helps (& makes sense)
David
