Ancient Bog Oak - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 08-15-2012, 08:57 PM   #1 (permalink)
Photos: 0
Default Ancient Bog Oak
Ok, I need emergency advice!
I have an order for a fountain pen using Ancient Bog Oak. I tried finishing it with CA (this is the standard finish I use on all wood pens) and I had a terrible time with it. The CA is not adhering well on the ends and it is lifting off the wood. I am using CA thin as it normally works best as it soaks into the wood and adheres well. I didn't notice that the bog oak was oily but thought maybe I should sand it down and use some alcohol to rub the wood down, dry it well and re-apply. I did this and had the same result. Also, I do not use any wax on the bearing so that wasn't the problem.
So.....does anyone have any advice as to an alternative finish? I was thinking of trying 2 step friction polish (I have some on hand). I stopped using it because I don't believe it holds up well when the pen is used regularly and want a quality finish that holds up and a happy customer.
The other thing I didn't like about the CA was that it basically turned the bog oak all black and you really couldn't enjoy the grain and multiple shades of black, grey, and brown.
Again, any thoughts on a quality finish that keeps the pen more natural looking? Any advice would be appreciated.
Mike
mdwilliams999 is offline   Reply With Quote Top
Old 08-15-2012, 09:14 PM   #2 (permalink)
seamus7227's Avatar
Photos: 150
Default
well, unfortunately i dont have any words of encouragement for you. But I have been in the same shoes and had to give up on the CA finish because of the same problems. I ended up going with a friction polish.
__________________
Home of the Tru-Quarter™ Blanks. Follow me on Instagram/Facebook too!
http://www.texomapens.com
"My home is in Heaven. I'm just traveling through this world."
-Billy Graham
seamus7227 is offline   Reply With Quote Top
Old 08-15-2012, 09:37 PM   #3 (permalink)
Chapter Steering Committee
ssajn's Avatar
Photos: 0
Default
I've used Bog Oak a few times and find that Woodturner's Finish from General Finishes works real well.
I find it also works well on ebony, blackwood, rosewoods and other oily woods.
It leaves the pen with a more "wood" like look and feel rather than a plastic look and feel you get from CA. It also holds up better than any friction polish I've used.
__________________
Dave
Wisconsin Chapter Leader
http://woodjunky.weebly.com/
My money talks to me, it says good bye.
A penny saved is a government oversight.
ssajn is offline   Reply With Quote Top
Advertisement
Old 08-15-2012, 09:42 PM   #4 (permalink)
DestinTurnings's Avatar
Photos: 0
Default
You can try wiping the blank with CA accelerator prior to applying your CA finish. You can also use Bullseye sanding sealer before the CA. I have had good luck with both.
__________________
Dave Rogers
Destin, Fl
USAF Retired
IYAAYAS
DestinTurnings is offline   Reply With Quote Top
Old 08-15-2012, 09:57 PM   #5 (permalink)
StephenM's Avatar
Photos: 0
Default
Are you sure it's really bog oak? Bog oak sits in a bog for hundreds or thousands of years and the minerals in the peat/water are absorbed into the wood turning it a glossy black. I've worked with a lot of bog oak from Ireland and have never come across an oily piece. Oak itself isn't an oily wood and the bogs by definition, are water, not oil.
I have had some with dark brown veins and have a piece from the core of the trunk that has a large streak of light gray running through it but as soon as any liquid finish touches it, they both turn very dark - not quite black but darn close.
That being said, I've always finished bog oak with shellac and wax. Think of it as french polishing the pen but the lathe is doing the work of your arm. You're basically building up 10, 20, 30 very thin coats of shellac until you get a nice sheen and then finish it up with wax.
StephenM is offline   Reply With Quote Top
Old 08-15-2012, 10:04 PM   #6 (permalink)
firewhatfire's Avatar
Photos: 14
Default
I clean oily blanks with a lot of acetone. It seems to help me on them.
__________________
“I shall pass through this world but once. Any good therefore that I can do or any kindness that I can show to any human being, let me do it now. Let me not defer or neglect it, for I shall not pass this way again.”
― Stephen Grellet
Deuteronomy 31:6
Romans 14:8
firewhatfire is offline   Reply With Quote Top
Old 08-15-2012, 10:07 PM   #7 (permalink)
JD Combs Sr's Avatar
Photos: 0
Default
What Stephen does is nearly the same thing as WTF(wood turners finish) so +1 on WTF, it is loaded with shellac and a solvent as well as some other goodies.
__________________
JD at J&J WoodSmithing
Owingsville, Kentucky
Also find me on FaceBook at:
https://www.facebook.com/jnjwoodsmith
JD Combs Sr is offline   Reply With Quote Top
Old 08-15-2012, 11:25 PM   #8 (permalink)
alamocdc's Avatar
Photos: 232
Default
Quote:
Same for me. If you want to try CA wipe them down with acetone before you finish. It should flash off fairly quickly and give you time to get the finish on.
Another option would be a plexiglasss/acetone finish. I think Chris (Wishman) has a tutorial on it. It's quick and it's durable. And it polishes to a high sheen. I'd still wipe the blank with acetone first.
Now, for what I would actually do: I use lacquer on my bog oak... always. The only problem with lacquer is the dry time (about a week, minimum, so you better be serious).
__________________
Billy B.
San Antonio, TX
www.acdcreations.com
"It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
alamocdc is offline   Reply With Quote Top
Old 08-16-2012, 09:20 AM   #9 (permalink)
jd99's Avatar
Photos: 1
Default
I've turned a half dozen bog oak, and never had any problem appling CA.
My Method:
  • after I square the ends, I soak the ends with thin CA.
  • Turn the blanks to the TBC Bushings.
  • Remove the bushings and put the blank on the lathe between centers.
  • sand down to 400 (dry sand).
  • Clean blank with DNA.
  • Apply 5-6 coats of thin CA, and apply accelerator.
  • Sand with 400 (dry sand) to get the blank smooth or close to smooth, (I only do this with Oak blanks due to the CA soaking into the blank so much)
  • Clean with DNA
  • Apply 5-6 coats thin CA, and apply acelerator
  • Apply 10- 15 coats of med CA, and apply accelerator (I put on 5 coats then apply accelerator)
  • Let cure over night.
  • I sand the ends (I reverse my squaring tool and put self stick sand paper on the back end) to remove excess CA buildup on the ends.
  • Wet sand 400 to 2500, then MM through the grits, then buff with tripoli and white diamond.
Hope this helps.
Note# The Bog oak I have is black any how, even after sanding, the CA finish helps bring out the grain better then friction polish on the stuff I have.
jd99 is offline   Reply With Quote Top
Old 09-04-2012, 05:14 AM   #10 (permalink)
Photos: 0
Default
Hi all
I have great results with floor varnish. The quick dry stuff. Works a treat.
__________________
Regards
Roger
Let the wood chips fly.
Due to the world economic situation the light has been switched off at the end of the tunnel.:eek:
rogerwaskow is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
ancient bog oak , bog oak , finish
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
