Acrylic Finishing Pads
donstephan
Cincinnati Ohio
Does anyone know of a source for full sheets of the acrylic and corian finishing pad kit sold by Berea Hardwood (and probably others). Each of the pads is two sided, and the colors correspond to different grits. I'd love to get an 8.5 x 11 sheet of the 12000 grit for rubbing out varnish on turned wooden bowls.
CREID
Vancouver, wa
Try searching for Micro Mesh. But I haven't ever seen an 8 1/2 x 11 sheet. Their may be one though, maybe someone else has a better answer.
Charlie_W
Sterling, VA USA
Check in with Barry Gross at Arizona Silhouette. The pads at Berea look to be the same as his...different grit on each side. I use them on CA but do not even use the course grit...sometimes not even the two course-est grits.
Good luck on your quest!
