2015 Limited Modification Kit Pen Poll
Which is the best Limited Modification Kit Pen?
  • Pen 1
    Votes: 6 5.1%
  • Pen 2
    Votes: 21 17.9%
  • Pen 3
    Votes: 5 4.3%
  • Pen 4
    Votes: 1 0.9%
  • Pen 5
    Votes: 3 2.6%
  • Pen 6
    Votes: 27 23.1%
  • Pen 7
    Votes: 3 2.6%
  • Pen 8
    Votes: 51 43.6%
  • Total voters
    117
  • Poll closed .
mmyshrall
Spokane, WA
Well folks, another contest is over for the 2015 IAP Birthday Bash.
Now its your turn, please select your favorite pen from these 8 entries. The top three vote receivers will be used to determine the first, second and third place entries.
I want to express my gratitude to all of the entrants for their work and wish them the best of luck. I know that at least one of the entrants has not previously posted a photo on the IAP; it takes a fair amount of courage to put your work out there for everyone to judge. Please show your support and appreciation for their effort by voting.
I wish the best of luck to all of this year's participants and look forward to announcing the winners on February 22, 2015 since a second round of voting will not be needed for this contest.
Thanks,
Michael
mmyshrall
Spokane, WA
Pen 1
Kit Used: Euro 7mm
Here's the plain old Euro all dressed up in Amboyna Burl, segmented with Ivory. Carefully handcrafted and finished in a deep CA. The Kit centerband is replaced with one of Ivory, perfectly matching both barrels.
mmyshrall
Spokane, WA
Pen 2
Kit Used: Black Ti Designer/Euro
I used Ebony for the wood and replaced the Center band by inlaying a band of Abalone.
mmyshrall
Spokane, WA
Pen 3
Kit Used: PSI Trimline
This is a PSI Trimline in Gunmetal. The blank is a "Thank You" from Ernie at Bear Tooth Woods. This is my first attempt at a custom finial.
mmyshrall
Spokane, WA
Pen 4
Kit Used: Berea Slimline
I removed the centerband and made the lower blank longer and fatter than normal. I then turned the lower barrel in the shape shown so that a portion is larger than normal. Then I bored out the enlarged portion to accept the upper barrel. The fit is quite close so that there is no "wiggle" as there usually is with the normal construction. The pen twist operates as normally and the pen is firm to hold. A few shallow decorative grooves were cut around the enlarged portion of the lower barrel.
mmyshrall
Spokane, WA
Pen 5
Kit Used: Satin Pearl European Pen
Cross-cut Purple Heart with Acrylic replacing the center band.
mmyshrall
Spokane, WA
Pen 6
Kit Used: 24k black clip slimline
Cocobolo and purple heart sandwich with zebrawood inlay.The celtic knots were done simultainiously,swapping the offcuts before each glue up.
mmyshrall
Spokane, WA
Pen 7
Kit Used: 7mm Black Chrome European
The 7mm kit I chose is a Black Chrome European available from Bear Tooth Woods. The material is Alternate Ivory, commercially available from Exotic Blanks. For the modification, I chose to remake the nib from a piece of Corian. This was a fun project. I think this pen will stay in my collection for a while.
mmyshrall
Spokane, WA
Pen 8
Kit Used: Chrome Slimline from WoodCraft
This Chrome Slimline pen came from a Woodcraft kit. I have substituted the center band with one of my own making. The center was constructed of layered aluminum turned by hand on my lathe. The main body of this pen is a Malaysian wood (not sure the species). The red and black segments are Blood wood and Wenge separated by aluminum sheeting. The pen was finished with CA glue polished to 12k grit.
