mike4066
I went took some of the comments from the first post and here's my second shot at it.
I'll list how everything is setup to help answer any questions up front.
Camera:
Cropped & resized to 800x600 with MSPaint ZERO exposure/color correction. Yes I could do it RAW and run it through lightroom, but its installed on my other computer and the colors on that monitor are so far gone that I make things worse. I'd like to get it as right as I can straight out of the camera before turning to post processing fixes.
Other item of note:
I'm pretty sure I hit a limitation on the lens. When I filled the frame with the pen the top & bottom were soft. I tried setting the aperture as high as F22, changing the distance, and raising the camera so that the pen and camera were on the same plane. I couldn't keep the entire thing in focus. So I ended up using about 70% of the frame and cropping it down.
Camera:
Canon T3i w/18-135mm ef-s lens (switched from the G15 in the last post)
Got out the tripod
Lighting:Got out the tripod
2 of these with 5500k CFL bulbs on the Flashpoint Cool Light 1, 10.5" Reflector with One 55W Fluorescent Bulb FPCL1A (I found them at a second hand store for $20)
1 light in the front and above the camera
All 3 are covered with ripstop nylon
A silver reflector over the top
Settings: 1 light in the front and above the camera
Manual settings: F11 @ 1/25sec, 52mm
Custom white balance
Image stabilization off
manual focus
remote shutter release to avoid shake (any blur is a result of resizing/ and using MSPaint to do it, it was sharp before I resized it)
manual focus
Other item of note:
